Results 1 to 10 of 21
Thread: Acceptable engine compression? 86" 2.0l
    Bunbury, WA
    I am trying to chase down the cause of rough running with my 2.0l petrol in my 86". I have tested the engine compression as 110, 105, 100 & 105psi in cylinders 1-4. Tested "dry", ie plugs out cranking with no oil in cylinders. What would be considered acceptable before taking the off?
    The 100 is perhaps a little low compared to the others (leaky valve?), and I would have expected pressures about 5-10 higher, but they are not too bad. Have you checked valve clearances?
    Bunbury, WA
    I checked the tappet clearances today. Inlets were all good and not changed. Exhausts were a little big and were nipped up a little bit each.
    Bunbury, WA
    My main issue is a persistent miss at idle. I suspect the mixture is all out as it seems way too rich. It blows black smoke on acceleration. I took the compression readings as I suspected a valve or head gasket issue causing the miss??
    Sep 2012
    Westlake ,brisbane
    You could try a new set of spark plugs, if it is running rich & one of the pluge is week could be causing the miss. Also has it got copper or carbon leads if carbon you could have a faulty lead. Also check the points gap on all 4 lobes if one is worn that could also give a miss
    Bunbury, WA
    Yes it seems to eat plugs for breakfast. I have gone to one step hotter which has helped plug life a bit.
    The leads are new copper leads with new dizzy cap.
    If you needed to go to hotter plugs, I would suspect the rings are not in real good condition, which fits with the somewhat low compression (been there!). But this should not directly cause rough idling - worn engines often idle very smoothly. Other points to suspect are all the other ignition components, including coil, points and capacitor. But rich running at idle has to be a carburettor issue.
    Sep 2009
    What carb is on it?
    Paul
    Bunbury, WA
    Quote Originally Posted by Bundy View Post
    What carb is on it?
    Paul
    Solex 32PB-2.
    I've put a gasket and diaphram kit through it. Also sleeved the spindle which had some free play. No jets appeared blocked.
    Bunbury, WA
    Mmmmm. On start up cold this morning there is a definate diesel type knock, which does go away when everything warms up. The oil pressure gauge (smiths mechanical gauge fitted) shows oil pressure from startup though....
