Results 1 to 10 of 18
Thread: Windows 10 april upgrade PIN
    Garfield, Victoria
    Hi All,
    Since the recent April upgrade to Windows 10 I am experiencing a most annoying request on bootup to install a PIN for login rather than using the password. I do NOT want to use a PIN after a previous disaster which forced a Windows re-installation.
    The problem is that the only way to get past this PIN request screen is to select "install PIN later". There is no option to stay with a password as in previous Windows versions.
    I will not be forced by Microsoft to do something I don't want, so does anyone have any clues on how to stop this annoying message appearing at bootup. This morning I had to force stop the machine in order to get past it & it is very annoying.
    Any information would be appreciated.
    Lionel
    Avoca Beach
    If you go to Settings, then accounts, there is the option to change your password or add a PIN.
    I wasn't game to press add but maybe you can delete it or put in 0000 . You must have added a PIN sometime in the past.
    The only other way I know of is to start a new account , but then you lose all your favourites and contacts? ( not sure).
    Regards Philip A
    Garfield, Victoria
    Thanks for the reply.
    Actually, the point of my post was that I do NOT want to set a PIN. The only option in Settings>Accounts>Login options is to set a PIN. BTW, I have never set a PIN up to this point with my current installation (re-installation after a disaster trying to use a PIN!).
    I did see one suggestion to go ahead at the login screen & set a PIN, then later get into settings & cancel it, but another post said that they had tried this method & then found that the cancel option had gone from settings, so I am not prepared to take the risk.
    It seems that since the April upgrade, Microsoft are forcing us to use a PIN for login, whether we want to or not. I strongly object to this!
    Lionel
    Avoca Beach
    Well I have 1805 and kept my password ,but you never know wit Microsoft .
    Regards Philip A
    Mine upgraded this morning - nothing about now requiring a PIN.
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    Yet to see anyone forced to use a pin
    I do use one myself as i find it more convenient
    Sounds like something is out of kilter to me
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Garfield, Victoria
    Quote Originally Posted by Ferret View Post
    Give it time! Mine took about 3 days before it started badgering me about installing a PIN!
    Lionel
    Garfield, Victoria
    Quote Originally Posted by incisor View Post
    Mmm. I can assure you that I'm not the only one complaining about this. There are at least 50 posts so far on various forums.
    Unfortunately no-one has a sure-fire solution yet.
    Lionel
    Mar 2015
    Perth, WA
    I actually use it on one of my computers, and not on the other. I found the only way to stop being hassled (which I think is possible to ignore) was to add a pin and then go into settings and accounts and remove the pin. It hasn't started hassling me again since then.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    Quote Originally Posted by Lionel View Post
    Lionel
    i didnt say it didnt exist, just that i have never seen it on any windows 10 system, and i get to play with a few.
    my experience tells me it is something misconfigured, and you have have prior problems with it, so you have history.
    just make sure your microsoft account is upto date valid and working.
    sign into it using a web browser
    Microsoft account | Sign In or Create Your Account Today
    then go into settings on your computer, look at sign in options and turn it on, then turn it off if you don't want to use it to login.
    all the settings will be updated and that should be the end of it till something corrupts your settings again.
    if you don't want to have a working microsoft account your able to do that too but you will be running a slightling crippled system.
