No bar and probably need to get the tuff ant rims as no other choice to fit with big brakes.
Looking at a 2012 rrs tdv6 LSE
What rim tyres can be fitted for touring/offroad?
Anyone know if can get a front bar - winch bar?
What spare wheer carrier/rear bars has anyone fitted?
Finally what major issues to look for in a 125k km rrs?
Thanks for all advice
89 Orange Rangie UTE - our play thing - sadly now sold
75 Rangie/Series/Hybrid/LS3 - Bumblebee with a sting!!!!
2018 RRS - The new touring vehicle - replaces 2012 RRS
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
Things that usually go in the KLM range are, wishbones, compressor, alternator, air struts possibly. Got another 40k before timing belt is due, a search thru the posts should give you a good idea.
1974 VW Kombi bus
Found the posts on the mitch hitch - that will be one purchase so can set this up to tow off road van.
Seen the tuff ant rims - set of those will be needed for higher side wall off road tyres.
From what I have read the D4 and RRS are essentially the same vehicle except for body shape. More research on issues now needed.
Skiboy
Compomotive PD1881 also fit the big brakes (4-pot Brembos). 18x8" forged alloy, light and strong.
PD1881
Tyres = 265/60R18, 265/65R18 and 285/60R18. Can stretch to 275/65R18 with a bit of tweaking and finessing to make clearance. Anything bigger than the 265/60 requires deflation to fit the spare cavity. I've got a set of Tuffant steels with 285/60 muddies and a set of Compo's with 285/60 BFG ATs. One for everyday, and one for special occasions.
The D3 undershields/bash-plates bolt straight on (compressor, tank, trans, engine, front). I have a full set of APT's finest from Ben.
Tradesman (in Bayswater VIC) do a top-notch proper roofrack/cage for these (oval tube alloy) and you can customise the design as much as you like as they build to order. Mine's due next week
No complianced bullbar available at this time.
Be very wary of weights. The RRS has a low GVMR and high kerb weight (higher than homologated) so the real payload is quite low. My TDV8 povvo pack (stock) came in at 2740kg, with a 3070kg GVMR. Only 330kg of payload... I hope they don't weigh mine while I'm touring...
DiscoClax
'94 D1 3dr Aegean Blue - 300ci stroker RV8, 4HP24 & Compushift, usual bar-work, various APT gear, 235/85 M/Ts, 3deg arms, Detroit lockers, $$$$, etc.
'08 RRS TDV8 Rimini Red - 285/60R18 Falken AT3Ws, Rock slider-steps, APT full under-protection, Mitch Hitch, Tradesman rack, Traxide DBS, Gap IID
flush the auto if not done yet.
Current Cars:
2013 E3 Maloo, 350kw
2008 RRS, TDV8
1995 VS Clubsport
Previous Cars:
2008 ML63, V8
2002 VY SS Ute, 300kw
2002 Disco 2, LS1 conversion
 Wizard
						Subscriber
						Wizard
						SubscriberAn opposite lock D3/4 bar will fit with experienced fitters but is not ADR compliant. Some have used them your call.
 ChatterBox
						Supporter
						ChatterBox
						Supporter| Search AULRO.com ONLY! | Search All the Web! |
