Haven't actually used any of the NK stuff, but have seen it advertised in LRO and other mags.
Looks good quality, with some actual thought behind the application of each of the various products and some knowledge of acoustic theory and the relevant application to Land Rovers and other cars.
If I was in the UK, I'd consider buying it, but with a bit of searching you can find suitable local equivalents.
Same with the lizard skin, I think you can locally get rhino liner or raptor liner which are the same sort of thing. Someone on here has sprayed rhino liner on the underside of the wheel arch liners which is what I assume you're thinking of?
				Dan
'14 Def 110
'75 Lightweight
'98 300Tdi Disco (gone)
'80 2Dr Rangie Classic (gone)
