Results 1 to 10 of 12
Thread: Assistance for a newbie - 2 (yep 2) amigos diagnosis
    Mar 2018
    Lawson, NSW
    Hi all, first post here, other than in the 'Introductions' section. Thanks for having me!
    Bought a TD5 D2 a few months back, had it's first trip shortly after (a weekend camping trip down over the Kowmung, Kanagra Boyd NP), been loving having it. Installed a CDL lever recently, and looking forward to doing a few more bits and pieces to it.
    The TC light flashed on a week or go, but went off after i restarted the car.
    Alas but it returned, this time with the Hill descent light also and they seem to be hanging around, the come on right away when the ignition goes on (to be specific, they briefly disappear when most of the dashlights disappear, but return a second later).
    I've started on the ultra basic suggestions - checked and cleaned the earths, cleaned the plugs on the module.
    The lights persist.
    From all advice I've read it more or less becomes a guessing game from here on, and if the lights are fixed they won't go until being reset regardless, therefore best next step is to get the system read for faults?
    Is that a reasonable reading of the situation?
    With that in mind, how are my chances of finding someone around here keen to plug in a nanocom/similar?
    Thanks in advance for any assistance
    Robby.
    Free Again Thanks Dan
    We have a member in Orange (Muppet) im not sure if he has one
    Jul 2014
    west of Transylvania
    Hi, provided the ABS warning is coming on and go out(so not missing) there is one fault which is covered by the diagnostic protocol for the TC and HDC warnings on alone: Engine data, Sticking throttle, signal failure, data corruption - which can be the result of a bad contact or a wiring issue on the hardwired data bus between the engine ECU (black plug pin 32) and SLABS ECU(C0504-10) .... is the vehicle manual or auto? ... on autos the TPS used to trigger this fault code more often but it would have had other symptoms too
    Mar 2018
    Lawson, NSW
    ah, ok, that's interesting.
    ok just checked - the ABS light isnt coming on at all as I turn ignition on (I assume it's supposed to?), so prob just missing/not lighting up.
    Probably usual 3 amigos then.
    Another question - will TC work with amigos? or does it vary?
    I might try to get out for drive this arvo to test.
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by thetravellingleunig View Post
    The error you are getting is because the CDL was deleted in pre update D2's and once reto fitted will throw that error each time you lock the CDL with engine running, the fix is to cut a wire and add a switch.
    Should be a post about the mod here some where.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jul 2014
    The CDL when it's locked will trigger only the ABS and TC without the HDC so not the case here... in this case it's the 3 amigos and the ABS warning might be blanked ... make somehow to read the fault code and see why the ABS warning is not visible, in most cases it's black tape in front of it within the cluster
    Mar 2018
    Lawson, NSW
    thanks for the comments sierrafery and loanrangie.
    I do indeed had a CDL lever installed (the only mod I've done so far, but one I am very glad to have, particularly in light of below), but that isn't related, as sierrafery says it looks like its the 3 amigos.
    Test drive this arvo suggested that TC isn't working, or at least not properly.
    Is this usually the case when the light is on?
    Get Out of Jail
    https://www.aulro.com/afvb/local_lin...catid=2&id=152
    Jul 2014
    In most cases yes, though there is a default where it does work but it's rare
