Results 1 to 10 of 13
Thread: Permanent In Caravan PC
    May 2003
    On The Road
    The usb port on our current telly is stuffed (though TV works fine) and we play a lot of movies off an external usb drive.
    I was thinking of building a permanent on-board PC to handle Movies and music and TV,,
    The Plantronics 2W speakers have always been ****, and the its resolution is stuck in the nineties,,
    as it happens I have a near new LG 32mp58hq available which has a 19v (around 3a?) input
    so all I'd have to power off my inverter is the PSU.
    Any suggestions on a OS for a media player/TV contraption?
    anyone bought a PCI-e TV card recently?
    Aug 2010
    Sunbury, VIC
    Haven't bought a tv card for a pc for about 15 years....
    But, have contemplated a pc for the van. Been thinking of a NUC or other small form factor units. There are cheapy units out there, but I'd probably spring for something decent.
    Not sure on what to do re the telly there though, I'm looking for other functionallity.
    Edit - you can actually buy a tv card for a NUC - what do you know? Whole unit ends up tiny and still packs a decent punch. Can easy put it nearly anywhere then.
    Western Victoria
    Get a TV and use it as a monitor.
    May 2009
    West Gippsland - Victoria
    .................... as it happens I have a near new LG 32mp58hq available which has a 19v (around 3a?) input
    Plenty of 12v dc to 19v dc laptop power supply bricks out there Pedro.
    Deano
    66 SIIA SWB .......73 SIII LWB diesel wgn
    86 RR 'classic'......99 Range Rover P38a
    94 Defender 110..95 Defender 130 Ute
    96 D1 300TDi.......99 D2 TD5 (current)
    04 D2a Td5..........02 Disco 2 V8
    May 2003
    On The Road
    Quote Originally Posted by Mick_Marsh View Post
    if I was just going to buy a TV I'd buy a replacement 12V one and forget about the PC
    NUC's,,, Hmm..
    May 2003
    On The Road
    Intel BOXNUC7I3BNK 7th Gen Core i3 NUC Barebone Kit [BOXNUC7I3BNK] : PC Case Gear
    does this read like it needs ram?
    well whadyaknow,,
    19V input...
    better and better.
    Aug 2010
    Sunbury, VIC
    To me it reads like it needs RAM and storage - and a TV card...
    The complete ready to roll units are more pricey - Intel NUC 7 Home Core i3 Mini PC with Windows 10 [BOXNUC7i3BNHXF] : PC Case Gear
    It is cheaper to buy the bits and screw it together yourself though.
    Aug 2010
    Sunbury, VIC
    TV card lid for NUC - showing out of stock everywhere I look though - Intel NUC LID with WinTV-HVR-955Q TV Tuner by GORITE
    Not sure if that unit works here either, but there are small USB style TV tuners which you could either plug in, or pull apart abd fit inside the NUC's case with some mods if you wanted to keep the form factor intact on the unit.
    I bet something like this - RTL-SDR RTL2382U 0.5 PPM TCXO Software Defined Radio Scanner USB Dongle AC1286 4894663410421 | eBay - could be made to fit inside with a few mods. 👍
    May 2009
    Hi Pedro,
    For a plan b how about getting a fetch TV mini set top box (about 100mm X 100mm X 25mm) and runs off 12 v dc Connect it to the HDMI port on your monitor (powered from the previously mentioned laptop power brick) and with its remote control you'll have full control from the comfort of your caravan armchair not only to all DTV stations but to internet TV, catchup TV, Netflix etc from its WiFi connection back to your 'hot spot' enabled smartphone (or park outside a Maccas) . Connect your NUC or whatever to the monitor D sub for other internet/computer access. A mini wireless keyboard/trackball completes the system for the tech savvy armchair warrior.
    A tick in every box
    Deano
    Jan 2017
    Geraldton WA
    As you can get flat screen TV's now for practically peanuts why not just get another TV and run the audio through the caravan stereo if you want better sound?
    4.6m Quintrex boat
