Results 1 to 10 of 12
Thread: SDV6 reliability
    Jun 2018
    NSW
    Post SDV6 reliability
    Hi Guys,
    I've had a look on forums and carsales to see what owners are clocking up on their SDV6. I haven't really found anything so I wanted to see what your experiences are on SDV6 with reliability etc.
    Our 2013 MY14 RRS SE SDV6 has clicked over 250,000km's and still feels tight, and fuel efficient around town.
    Fingers crossed!
    Dec 2011
    No issues with my 2011 L320 SDV6 SE.
    Car has now been replaced with a 2017 L494 SE but with the TDV6 motor.
    As the car is 400KG lighter than the L320 I don't miss the loss of the second turbo.
    Performance of the TDV6 feels better if anything due to the lighter car weight and eight speed gearbox.
    A plus is that and I have one less turbo and associated control systems to worry about!
    Barry
    Dec 2011
    Bundeena
    Quote Originally Posted by Barryp View Post
    Barry
    Barry, the TDv6 in the L494 has the same output as the SDV6 on the L320 (+ 10KW for the L494). So with the L494 being lighter you have a much more nimble vehicle. Also, all versions of the diesel V6 have two sequential turbos. That's why you have that massive amount of torque available virtually from idle.
    Sean
    Dec 2011
    Interesting that the workshop manual only shows one turbo on L494 TDV6 and when I have a look I can't see one where it was on my L320 SDV6.
    Totally different EGR and turbo system on the TDV6 from what I can see on mine and in the manual.
    Barry
    Dec 2011
    Pictures L494 TDV6 on the left and L494 SDV6 on the right.
    Small hole above the exhaust on the TDV6 is the new style low pressure EGR system that draws cooler exhaust from back near the DPF, SDV6 still uses the high pressure EGR system that draws exhaust from near the turbos on that engine.
    Note nothing under the right hand manifold on the TDV6. I hope this helps.
    Barry
    Mar 2007
    Warwick Qld
    Yep! That exhaust gas is going to be so much cooler! Still have issues with understanding how you can put dirty air into an engine, and profess to make it run cleaner.
    Same as back in the '70s when the anti-pollution stuff first came in. You set up an engine to burn more fuel, to produce less power, and call it a "cleaner" engine!
    1999 Disco TD5 ("Bluey")
    1996 Disco 300 TDi ("Slo-Mo")
    Dec 2011
    Bundeena
    Barry
    Thanks for that. Interesting change. Never assume anything I think they say. I'll have to have a closer look myself. Even the 155KW TDV6 of discos past have two turbos.
    Sean
    Dec 2011
    Bundeena
    Quote Originally Posted by donh54 View Post
    Defies all logic doesn't it?
    Sean
    Aug 2014
    SW Victoria
    I have a 2014 TDV6 which has twin turbos. They have changed since. I wonder what the turbo lag is like with the new versions, mine can be a pain in the backside particularly when trying to filter along gently in slow traffic.
    Cheers, Simmo
    Dec 2011
    My L494 with TDV6 has virtually zero lag compared to my L320 with SDV6. Can't guess why, but 8 speed auto vs 6 speed may help off the line.
    Barry
