Results 1 to 10 of 25
Thread: Half shaft splines
    Feb 2018
    East Gippsland
    Half shaft splines
    I have spent today stripping the front axle of my 64 shorty. I was really happy - until I pulled the short half shaft. For some reason the splines on both the shaft and drive flange were really flogged! The diff side were ‘perfect’ as well as the u joint. I can only think there was a lack of lube at some stage
    My question - when I see the price of the shaft replacements- has anyone had new splines milled or is it possible to find reasonable second hand?
    The drive flange is affordable, but not the shaft.
    Thanks in advance.
    I have just tried several times to attach a photo but been told ‘we’ have a problem.
    Sorry
    Narre Warren South
    To get new splines machines you'd have to build up with weld first. An expensive solution.
    Not too expensive from the UK.
    Stub Axle Shaft - Paddock Spares
    Just need to add a new universal joint and the seal collar Stub Axle Collar - Paddock Spares
    I could probably find secondhand ones for you but they will also need universal joints, seal collars and halfshaft bearings. Splines are OK but rust has got the better of any bearing or seal surfaces.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Jul 2011
    Yarrawonga, Vic
    I actually 'temp repaired' a flogged out 10 spline on a series 2 using Devcon ( JB weld ). I did thousands of miles on it and sold it on , telling the new owner about the bodge repair . He was a fellow club member had it for years of trouble free 4WDing.
    something like this
    Spline Shaft Repair
    YouTube
    I have milling machine & ability to make a new spline , but don't have metallurgy skills to anneal the axle spline & re heat treat it after repair . As a field repair I would use JB again no problems. ( I don't think it would work for 24spline though)
    Feb 2018
    East Gippsland
    Thanks guys - I had only seen the complete shaft for sale at +£300.
    The Paddock solution seems where I am headed. While I have the whole thing apart I really don’t want to do anything I will have to revisit.
    Narre Warren South
    Quote Originally Posted by Ricrose View Post
    For some reason Paddocks don't list the inner part of the shaft unless the part number changed (I'm using a Series II parts manual).
    In my earlier post I listed the seal collar, I was having a blonde moment because this is on the stub axle......
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    JDNSW's Avatar
    Unusual for them to flog out in my experience - I wonder if it was running grease in the swivel?
    Apr 2014
    Blair Athol, Adelaide South Aust.
    I got some s3 fronts here maybe some s2a as well. S3 are 24 spline outers tho i think. Id have to unearth them to lookHalf shaft splinesHalf shaft splines
    JDNSW's Avatar
    Quote Originally Posted by 67hardtop View Post
    Only long wheelbase, I think, except for late ones.
    Feb 2018
    East Gippsland
    Hi Gromit
    I have ordered from Paddock a couple of times and didn’t realise they had a whole catalogue not listed under the headings on their website. Didn’t really think that one through did I!
    Thanks.
    Narre Warren South
    Hi Gromit
    Thanks.
    I found out by accident. Had a part number for something and typed it in and they had it but it didn't show up in the category for that product !
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
