Results 1 to 10 of 15
Thread: D3 Key problems.
    Jun 2010
    Central Coast NSW
    D3 Key problems.
    One of our keys has started to have issues - it will sometimes unlock, then lock straight away. Sometimes it will unlock as normal, but then when you try to lock it the car thinks a doors open and beeps. Then when you open the car the alarm goes off.
    The second key seems to work just fine.
    I had thought it might be a low battery or a sticking button. Anyone else had this issue?
    The keys are glued shut pretty well so it seems I will be breaking the case to take it apart. Any tips there?
    Dan
    Jan 2010
    Bunbury WA
    the symptoms sound erratic but just guessing I suspect they might be related to a failing battery. Best practice is to keep both keys regularly used in order to keep cycling the batteries.
    Regardless, the battery might be at the end of its life. In which case a bit of open-heart surgery is required.
    You can buy the replacement cases easily off ebay. I bought 2 and the best quality one came from the UK ebay.
    There are a few how-to guides on YouTube, which I found helpful and also good info on Disco3.co.UK website.
    My advice is to use a Dremel (style ) tool to cut it open, and to buy the Gel version of superglue, I think Loctite do a Gel version.
    I cant recall which battery is used and its possibly a solder to the circuit board style.
    Jun 2010
    Central Coast NSW
    Thanks vee8auto
    It is the key that's used everyday, and I think the case (or at least the buttons) has been replaced once already.
    Do you remember what battery they need? I'd like to get the case and battery together before I destroy the old case.
    Dan
    Hornsby
    Jun 2010
    Central Coast NSW
    Thanks goofyr
    Just checked this key case and it comes with a battery too.
    Fob Remote Key Case Shell 3 Buttons With VL2330 Battery For Land Rover Discovery 6930401903195 | eBay
    Quote Originally Posted by goofyr View Post
    St Helena,Melbourne
    1.13 MB
    Dan, you have prompted me to start using my spare key before it dies, i have a spare shell to swap over but will see how the battery lasts before i do in case i need a new one.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jun 2010
    Central Coast NSW
    Haha glad I could help Nick!
    I have ordered the replacement case with battery (photos show it as a Panasonic battery) and it should be here before the end of the week. Hopefully the new battery fixes it!
    Jun 2010
    Central Coast NSW
    Finally got the key swapped. When I opened the old case there was what appeared to be condensation, but after sitting there for a week it hadn't evaporated so not sure what it was.
    Once I cleaned said residue off the circuit the key seemed to work fine, but I figured I may as well change the battery over. Long story short, my soldering iron was having a hard time heating up solder wick to draw the solder out. Literally took over an hour to desolder the battery. Took about 2mins to solder the new one in.
    Thankfully it all works as it should and I didn't bugger it up!
    Dan
    Jan 2010
    Bunbury WA
    Quote Originally Posted by Disco-tastic View Post
    ...When I opened the old case there was what appeared to be condensation, but after sitting there for a week it hadn't evaporated so not sure what it was. ....
    Dan
    'condensation' was most likely the acidic weepage that comes out of a failing battery.
    Needs to be cleaned well, with something like a printed circuit board cleaner spray from somewhere like Jaycar, etc.
    Note - Dont use any old solvent on a valuable printed circuit board. Make the effort to get a dedicated product.
    Jun 2010
    Central Coast NSW
    Quote Originally Posted by vee8auto View Post
    The battery I removed looked to be in fine condition - no swelling or anything.
    There was a fine mist over the circuit which I dabbed clean with a cloth - is it worth pulling it apart and cleaning or will such a small amount be OK?
