Results 1 to 8 of 8
Thread: County diff housing
    lowy Guest
    County diff housing
    Hi all ,
    My perentie / county front diff housing has taken one too many hits, and will need replacement At some stage .
    I just wanted to know what year would be a direct replacement ? I was hoping to bolt my swivel ball housing etc straight up as all else is good ,
    should my my first choice be a 130 ,then 110 and maybe a discovery ? what years would be a cut off point to bolt straight up ?
    Brisbane, Queensland
    Quote Originally Posted by lowy View Post
    Hi all ,
    I’d keep an eye on Grays auctions. They have front axle housings come up for sale. You might pick up a RFSV type housing.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Jun 2014
    Waitakere, New Zealand
    You could always cut the old center off and weld a Gwyn Lewis cover on...
    HD Weld on Diff Pan – GwynLewis4x4.co.uk
    lowy Guest
    Quote Originally Posted by rar110 View Post
    Good plan , I'll keep my eye's out
    lowy Guest
    Quote Originally Posted by BadCo. View Post
    They look pretty good ... My problem is , Mine has a nasty dent in the bottom as well .
    Jul 2008
    I've got one (1985 county) you can have it for nix.
    Pick up only. PM
    Watch the arms the earlier county ones have different distances between in the clevis pins.
    Clive
    Jun 2014
    Panel beat and plate it?
    Wheelers Hill, Melbourne
    I bought a Perentie that had hit a rock at high speed & munched the front diff - housing was obviously cactus too.
    I found that the same year Range Rover diff housing fitted exactly. Simply unbolt the swivel housings & re bolt up. In my case I needed the diff too.
