Thread: Running a fridge/cooler with a Solar Panel
    Hornsby
    Hi,
    I just wanted to find out whether you can run a fridge/cooler directly with a solar panel or must you have something in between (like a battery/pwerpack or regulator)?
    Thanks,
    goof
    Goof
    I suppose it would be possible, depending on the type of fridge, but not advisable. A panel can put out anything up to about 26V.
    IMHO there's only one way ... the right one
    That's via a regulator and battery. Think of the batt as supplying the power in the 1st instance, with the SP topping it up along the way.
    johnv Guest
    Agreed. depends on the size and output of the panel, but you definatley would want to be safe and use a regulator and battery, Don't connect panel directly to fridge
    Hornsby
    Originally posted by Rosco
    Goof
    Thanks Rosco, I guess if I wanted to connect the solar panel and the cooler (waeco TC32FL) to the battery at the same time I need some way to isolate them.
    goof
    goof
    Shouldn't be a prob. I have an 80W jobby permanently roof mounted and wired through a solar reg. Then just switch on the Waeco when required.
    It's not rocket science, 'cause if it was I'd be stuffed for sure
    Feb 2005
    you will need a reglator and battery with out question when using a solar panel to run an appliance, which i'm sure you are planning to use otherwise the fridge would not work at night.
    springers (12V shop) at brendale have a 40L Waeco running inside the shop with just a small battery and a 80W solar panel on the roof. it been running for at least 12 month non stop. keep in mind that it's in a aircon showroom all day so the fridge is not working all that hard.
    an 80W panel would be the minium to run a 40L fridge. somebody could probably explain this better than me or a web sight but i will give it a go on a 40L engle fridge current type.
    Fridge
    max current draw per hour 2.5amps
    say the fridge cycles at 50% that would mean it would draw 1.25amps/hr = 30amps out of the battery over a 24hr period
    solar panel
    80W BP
    Max current output 5amps/hr
    say you keep moving the solar panel so that you get 8hrs of direct sunlight you would put 40amps back into the battery
    factor that will affect the whole setup;
    the more you open the fridge the more it will cycle
    solar panel not square to the sun
    clouds
    shade
    i have nearly convinced my dad to buy a 120W bp to run his 40L engle and a fluro in his camper van, only problems is he's made keen on a generator which are noisey, got to carry two fuels, not allowed to use them at a lot of places etc
    hth
    P.S.
    And don't forget a diode between the panel and batt, to prevent back flow.
    Bracken Ridge, Brisbane
    I wanted to do the solar panel thing but to many $$$ to run a cf80
    Hornsby
    P.S.
    I thought you said it wasn't rocket science!
    Thanks for the input guys, I'll be researching a little further, but at least now I have an idea how to hook it all up and what to consider.
    Much obliged.
    goof
    When looking at the numbers, remember that the 5 amps for the 80W panel is the maximum, not the average - realistically you'll probably average 3 amps. And get anywhere inland in summer and that fridge will have the motor running pretty close to 100% of the time - unless its in the car with the aircon going.
