Results 1 to 6 of 6
Thread: Auxiliary battery location?
    Can anyone post pics of where.how installed an auxiliary battery in their RRS L320 V6 model (2012 specifically).
    I am looking for ideas on where and how to mount fridge battery.
    Has anyone mounted a lithium battery (smaller) in the rear anywhere?
    Thanks in advance
    Skiboy
    89 Orange Rangie UTE - our play thing - sadly now sold
    75 Rangie/Series/Hybrid/LS3 - Bumblebee with a sting!!!!
    2018 RRS - The new touring vehicle - replaces 2012 RRS
    Oct 2011
    Sunshine Coast
    I’ve got a Traxide dual battery set up with Optima D34 battery sits just in front of main battery will take a pic tomorrow. Contact Tim Drivesafe or Google traxide dual battery kits. Purpose designed for these cars. Has worked flawlessly for last 5 years
    Oct 2011
    Sunshine Coast
    These were photos incisor took
    traxideecclesRRS0 | Dave Blears | Flickr
    Quote Originally Posted by Meccles View Post
    Thanks - yes know Tim was out there last month to pick up a usi -160 unit for Bumblebee my off road hybrid. I see it uses the same unit. Like the way can also plug solar in the back.
    So will use his gear it was more where to locate the battery.
    pics a great help thanks
    Skiboy
    Queensland
    Quote Originally Posted by Skiboy View Post
    Hi Skiboy, if you fit a lithium in an RRS ( and any other vehicle ) to charge it properly, you will need a DC/DC device.
    At this time, it is not really that advantageous to fit a lithium battery system over a standard battery setup in your RRS.
    BTW, I now sell Sterling Battery to Battery ( DC/DC ) gear, for lithium battery setups, but again, the standard setup is still the optimal way to go.
    Ok thanks Drivesafe
    Will be looking to get kit for RRS once I have it purchased (delivered end of month) to locate battery in front as per post above and your USI 16o.
    I will need Anderson in rear for van for 3way fridge plus your upgraded rear cig plug for fridge in car.
    I presume it is the D4 kit - not sure I follow the difference between all the options but the last one with the USI 160 allows the solar from the rear same as I got for Bumblebee is the one I think.
    Skiboy
