Results 1 to 10 of 11
Thread: Rotor thickness on RRC
    Perth WA
    Hi All,
    What is the legal thickness for Disc Rotors on 1992 Range Rover classic before they need to be replaced.
    Looking around this forum DBA seem to be a good brand ... and whats everyone's opinion on discs being slotted only or both slotted and drilled.
    The Rangie just doesn't seem to pull up as quickly as I would like ..... looking at all avenues.
    Baggy
    99.87 MB
    If you just do slow work then I think plain. If you tow, are in the hills etc then slots. Not ever cross drilled due to cracking.
    Good high performance pads (not racing pads!) will make a big difference.
    One of the old Rangies from Davis Landys, with air suspension, just about put me through the windscreen the brakes were that good.
    Slunnie
    Kingston, Tassie, OZ.
    The min thickness is 22mm
    St Helena,Melbourne
    4.28 MB
    Solid rotors its about 12.7mm from memory.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Perth WA
    Thank you to everyone for your response.
    Slunnie ...appreciate the advice and Justin for the link to new rotors.... now to check the rotor thickness on the girl
    Baggy
    Quote Originally Posted by Baggy View Post
    Baggy
    I only put that link in as it had a pic of the measurements... i wouldn't be recommending any overseas ebay or internet seller at all!!😟
    Perth WA
    Hi All
    Finally have time to check rotors on Rangie
    Apologies for stupid questions up front ...
    I looking at link Justin did is it correct new discs difference between. New (24mm) and minimum before replacement is 22mm .... Is that sound right?.
    Is that thickness (22mm) same for solid rear disc??
    My rear right measures 12.5mm with Vernier calipers?
    I'm about to Jack up the LH Rear and check it
    Baggy
    Perth WA
    Hi All
    My rears measure 12.5mm with Vernier calipers?
    Baggy
    Avoca Beach
    No, the rears are solid and the dimensions are given above.
    It is difficult to measure them with Verniers due to the rim which sometimes builds up on the outside.
    try micrometer on the middle of the swept area.
    Regards Philip A
