Results 1 to 10 of 28
Thread: On the road laptop charging (seeking a no inverter solution)
    Aug 2011
    Hunter Valley NSW
    Does anyone have a preferred solution for keeping laptops charged whilst on the road for extended periods?
    I'm avoiding running any inverters in the truck (why have 240v on the car when you dont have to) so I'm looking for a 12v direct laptop charger or maybe just use powerbanks.
    Have a look on your laptop power brick, it will tell you your power requirements in Volts & Amps.
    Most laptops are 18v+ now so a unit that steps it Dc-Dc is needed (also provides filtering).
    There are units out there. Let me know what you need and I’ll link a few.
    Aug 2011
    Hunter Valley NSW
    Thanks...I'll check the specs when I get home.
    Sep 2012
    Adelaide Hills
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Avoca Beach
    I had a power supply from Repco.
    First time I fired it up it lost smoke.
    Unfortunately it took out the power supply in the laptop.
    I had bought one with the same amps as the transformer.
    BUT it appears that their amps were not the same amps as the laptop transformer amps.
    So now I charge through an inverter.
    I got a refund for the 12v power supply but no regard for consequential damage to the laptop.
    Once bitten twice shy.
    Regards Philip A
    The unit I’ve had has crossed about 5 laptops now without issue.
    Plenty of cheap inverters will kill SMPS in short order.
    Aug 2011
    Hunter Valley NSW
    It's 20V 3.5a
    I had a quick look but I'm swamped by conventional chargers.
    Aug 2010
    Sunbury, VIC
    There are plenty dc to dc converters specifically designed for this purpose. I've got one from about 3 laptops ago still doing its thing in my car. I'll see if I can find a link.
    Aug 2010
    Sunbury, VIC
    This would work, but there are plenty more - 80W 12V Universal LAPTOP CAR CHARGER TRAVEL ADAPTER DELL HP TOSHIBA SONY ACER | eBay
    Has a pile of adaptors and output is switchable from 15 to 24 volts to cover all laptops. 80 watts will cover what you need.
    Search 'Laptop car charger'
    Aug 2011
    Hunter Valley NSW
    Quote Originally Posted by Homestar View Post
    That seems perfect...suspiciously cheap!
