Apparently you can turn them slightly and they won't pick up on it.
Our '16 D4 will only pick the Mitch hitch up every so often, so I haven't bothered messing with it.
 Fossicker
						Fossicker
						Since fitting the Mitch Hitch the sensors whale every time I select reverse.
If I could find out how to turn off the sensors I would. Alternatively can anything be done with the sensors to stop all the noise.
I know I can turn it off via the button but this is quite onerous.
'15 Discovery 4 HSE- The family bus and the kids like it!
'89 RRC- My favorite of the bunch!
Ex '03 Commodore 'S' ute- 450hp of uncracked 5.7lt and 6 speed manual uteness - Still crying that its gone
Ex '06 GLXR Triton- *Gone and forgotten*
No, don't touch the sensors. Simply go to Bunnings and buy a pack of clear surface protectors like these Madico 13mm Clear Round Vinyl Bumper Pad Surface Protectors - 24 Pack
Clean and dry the sensors, then take one protector and cut it in half with a razor blade. On the two inboard sensors only, place the half protector on the side of the sensor closest to the Mitch Hitch. Put the remaining protectors in a safe place that you will remember because you will only ever need to replace them once every year or two.
2013 D4 expedition equipped
1966 Army workshop trailer
