Results 1 to 10 of 17
Thread: Failure to Proceed
    terraaustralis Guest
    Failure to Proceed
    Greetings.
    2001 D2 Auto. TD5. 340,000+ kms. Improved reconditioned Auto four years ago. Probably less than 20,000 kms on the "new" auto-box.
    This event has been occurring for the last 12 months - on and off- not every time. Some intermittent fault
    An issue that has one stumped. Here is the situation: Turn on the engine - yes it idles as normal. Push the accelerator and no response. Absolutely none. Put it into gear and no progress forward or reverse though it seems to creep a few centimetres then stops. Turn off the engine and wait. Wait anything from 2 minutes to several hours (even the next day) and the beast awakens as normal and the automatic is fine. This can occur with a hot or cold engine. A lottery!!!
    XYZ switch is good. Fuel regulator replaced. Airflow sensor replaced. (plus something else I can't remember at present).
    Here's the killer - nothing appears on error code diagnosis.
    The car has been under the watchful care of a seasoned independent Land Rover Specialist shop with all the knowledge and diagnostic tools needed.
    Has anyone else experienced this?
    Melbourne car.
    Planning a Great Victoria Desert trip in August 2018. In the words of Ernst Shackleton: "Safe return - doubtful" (at present).
    Suggestions most appreciated in advance.
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    "seasoned independent Land Rover Specialist shop with all the knowledge and diagnostic tools needed"
    some times it might just be a case of taking somewhere else for a second opinion. It's happened before where experts couldn't find a problem and some one else has fixed it. Take it to a reputable Auto trans specialist .
    2nd opinion.
    Yes. This is my next move.
    Feb 2011
    Hobart, Tasmania, Australia
    My D2a TD5 seems to do a bit of what your describing every now and then - maybe once a few months and has done for years now. I start the engine, and it just sounds a tad different, put it into drive and push the accelerator and it won't increase the revs of the engine, almost like the accelerator pedal is disconnected. I find if I coast out for a minute or turn off and back on it's immediately resolved. Sadly not in your car which would be frustrating.
    Jul 2014
    west of Transylvania
    For the described issue the TPS is very suspect, live data reading is needed from tracks 1 and 2 when the symptom occurs, if the first readings are good but they dont react to the throttle position there will be no code logged cos the ECU will "think" that there's no driver demand just idle.... if the readings are OK next call is the fuel pump
    TPS
    Quote Originally Posted by sierrafery View Post
    Does this - TPS - stand for "Totally and Permanently Stuffed"?
    Error Code: Agreed! That the ECU is receiving "normal"signal - as it sees it. So, no error code appears. This pretty much rules out the ECU as the source.
    I know the fuel pump is good.
    Could it be the sensor on the Fuel Pressure Regulator? This I know as the FPR. (pretty sure I got that acronym right as I'm a bit of a Landie novice. Please forgive!))
    This ( Ï am not letting you go" business) has only been occurring since the FPR was replaced earlier this year. I am not sure if the sensor was replaced at the same time or even checked at all? There might be a short or bad earth, perhaps? The car is 18 years old. Contact corrosion in the FPR sensor - would this be a possibility?
    Should I just buy a new FPR sensor (or TPS thingie) and bung it in?
    Much appreciated.
    Oct 2011
    Fremantle WA
    Quote Originally Posted by terraaustralis View Post
    Much appreciated.
    By now you will have found out that it is the Throttle Position Sensor being discussed.
    and Sierrafery is one of our eminent gurus
    TPS
    That's great. My list of acronyms is improving. Thank you for the Sierrafery lead.
    Jul 2014
    The sensor in the FPR is for fuel temperature, it's easy to be ruled out, unplug it and if then the fault is gone you know to change it... albeit i doubt it could cause such symptom, i'd replace the TPS if i was you
    Free Again Thanks Dan
    Quote Originally Posted by gavinwibrow View Post
    And for the uneducated Throttle Position Sensor is your Accelerator pedal = Drive by wire
