Thread: Enamel paint, how many coats ?
    Jul 2016
    Hi All, I have just started some body work painting with Wattyl agricultural enamel, starting with the radiator surround.
    I thinned the paint 4 to 1, as recommended, so the paint is quite thin and runny.
    Does anyone have a view on how many coats should be required ?
    Maybe it's my technique, but one coat would appear to be enough.
    Any wisdom appreciated.
    Narre Warren South
    Data sheet says max 25% thinners (3:1).
    I've been spraying Protec alkyd enamel (camouflage green) and have used two coats. Partly to make sure I didn't miss any areas and also to give a slightly thicker coating.
    Problem is it depends a lot on how heavy each coat is, with a lot of thinners it might be a thin coat otherwise it will run.
    Data sheet mentions coating thickness per coat and gives a typical figure but doesn't mention how many coats.
    If re-coating be careful of the times they state. Within 4 hours or after 16 for the recoat.
    Wattyl also mention a Dry Add Urethane Additive to improve hard drying properties, humidity, wrinkle & solvent resistance.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Pretty much as Colin says - it depends on how thick a coat you are putting on. I did two on mine, but as far as I know, the original factory finish only had one coat!
    Bunbury, WA
    I assume you are spraying? I use acrylics but usually go 2x double coats to get enough paint on and a good finish.
    Jul 2016
    Thanks for input guys.
    Jul 2016
    Guys, I should have also thought to ask the following questions ..
    1. How long are you waiting between coats ?
    2. Are you sanding at all between coats ?
    Narre Warren South
    Quote Originally Posted by JohnboyLandy View Post
    With the alkyd enamel I'm using I give two coats fairly quickly, only giving it time to get touch dry between.
    With a solvent based paint it will dissolve the coat underneath and get a good grip but enamel paint may need sanding which means a long time between coats.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
