Results 1 to 10 of 22
Thread: 4WD TV - what a good show
    May 2002
    Sydney, Australia
    Well I finally managed to remember the show tonight - in Sydney its on TVS at 19.30 Thursdays.
    Being my first episode I was surprised to see SOOOO many Land Rover products, and even an interview with Andrew Richmond in his workshop.
    This was episode 55 - anyone have copies of the other ones? I would especially like to see the High Country ones - even if SClarke is in it
    LRH
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    Hobart, Tasmania
    Twas a good show. Glad to finally see some touring happening. Landys were a definite draw card too...
    South Sydney
    Excuse my ignorance, but what is TVS and where is it found on the dial?
    ____________________________
    Noddy
    - 'Kimba' ('02 Defender Xtreme 110)
    - 'Ari' (1994 Peugeot 205GTi Classic)
    "...we are all just earrings to the left of our parents, and they are all just haircuts to the left of theirs..."
    May 2002
    Sydney, Australia
    you've been away too long!!!
    http://www.tvs.org.au/
    Community TV Channel in Sydney - though 4WD TV is based in VIC
    Disco 4 SDV6 Auto
    RRC 300 TDI Auto
    Subaru GDA WRX
    Yamaha TTR250
    Hobart, Tasmania
    TUNE IN TO tvs
    Televisions have tuners that allow different channel settings to be memorised and stored on preselected positions on the television.
    The instructions that came with your television set are the best guide for tuning as the methods vary from model to model.
    If you do not have the instruction manual for your TV set, look for them on the web site of the set manufacturer.
    The instructions following are for some of the more common and some older sets.
    Manual Tuning for UHF 31
    Before tuning in your television, make sure the AFT (Automatic Fine Tuning) is switched off. On some sets this occurs automatically when the panel door or drawer is opened.
    Tuning a Turret Tuner set
    A turret tuner is an old style television without a remote control and with a round manual dial to change the channel.
    Turn the tuner to channel U, and rotate the UHF fine tuner to 31. Some sets have a VHF/UHF button to switch to U, before fine tuning to 31.
    Automatic tuning
    Press the pre-set button and the tuning band VH(H), VH(L) or UHF will appear on screen. Your television will automatically search for the television signals as they are located in order and display the channel number it has allocated for each.
    Press button sets
    Each channel selection button has its own band selector switch and fine tuning control, meaning any channel can be allocated to any button. When the fine tuning is completed, turn on the AFT button.
    Troubleshooting
    A good outdoor antenna will strengthen the signal. Indoor antennas can be problematic.
    A good quality coaxial cable is recommended. Many reception problems are due to the wrong antenna cabling. Ask your local electrical retailer if you are unsure about your cabling.
    A snowy image may indicate insufficient signal strength. It may be due to an obstacle, such as a building, between your antenna and the transmitter at Gore Hill. Try to relocate the antenna on your property. Obtaining a masthead (booster) amplifier may resolve this.
    Again talk to your local electrical retailer if you are unsure.
    May 2002
    Sydney, Australia
    Rodder’s Life was good also - just after 4WD TV
    LRH
    Disco 4 SDV6 Auto
    RRC 300 TDI Auto
    Subaru GDA WRX
    Yamaha TTR250
    South Sydney
    Originally posted by Omaroo+--><div class='quotetop'>QUOTE(Omaroo)</div><div class='quotemain'><!--QuoteBegin-Noddy
    TUNE IN TO tvs
    Automatic tuning
    Press button sets
    Troubleshooting
    Again talk to your local electrical retailer if you are unsure.[/b][/quote]
    Thanks Omaroo :wink:
    Noddy
    May 2002
    Sydney, Australia
    tonights show will be repeated on Sat at 16.00 & Sun 11.00
    both times followed by Rodders Life
    HTH
    LRH
    Disco 4 SDV6 Auto
    RRC 300 TDI Auto
    Subaru GDA WRX
    Yamaha TTR250
    Nov 2005
    Maudsland, QLD
    the dam Gold coast doesn't recieve the signal from Brisbane to watch the community channel, so it's painful to hear what i'm missing out on
    2023 Defender 130 D300
    SOLD - 2010 Discovery 4 V8
    SOLD - 2008 Range Rover Vogue L322 TDV8
    SOLD - 2006 Range Rover Sport L320 TDV6
    SOLD - 2002 Range Rover L322 TD6
    SOLD - 2002 Discovery 2 TD5
    SOLD - 1997 Range Rover 4.6 HSE
    SOLD - 1999 Range Rover 4.0 SE
    Queensland
    Maybe some nice person in Brisbane could make a copy and send it to us so we could run it at the next GCLRO Club meeting or just lend it out to members.
    Cheers and please, PLEASE.
