Results 1 to 10 of 20
Thread: fuel economy of recent trip, does this look right?
    Sep 2012
    Adelaide Hills
    12,000km
    $2000
    assuming $1.6/l
    1250l of diesel
    car computer indicated 12.4l/100km
    manual calculator is 10.4l/100km
    08 RRS TDV8 pulling 800kg camper
    larger tyres and engine tune.
    does this seem correct?
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Sep 2012
    Adelaide Hills
    oh, and sitting on 110km/h on the road when i could
    Current Cars:
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    Ean Austral Guest
    Yep , TDV8 shouldn't feel 800kgs on the rear, and assume the trailer is the same height or lower than the RRS.
    Cheers Ean
    Ean Austral Guest
    Quote Originally Posted by Eevo View Post
    My D3 is prolly more economical at 110 than 90, as it hunts gears at 90 and the revs are from 1400 to 2100 , but@110 it sits on 1400rpm all day
    Cheers Ean
    Sep 2012
    Adelaide Hills
    Quote Originally Posted by Ean Austral View Post
    i think the rpm at 110 was closer to 1800rpm.
    is there a way to tell what gear im in?
    Current Cars:
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    Ean Austral Guest
    put the foot down and see if the revs drop then you are not in top gear . .... not sure about the TDV8 might have the 8 speed box so you may need to do 115 to get top gear.
    Cheers Ean
    Sep 2012
    Adelaide Hills
    Cheers Ean
    its a 6 speed.
    well go for a drive...
    Current Cars:
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    Ean Austral Guest
    its a 6 speed.
    My TDV6 with 6 speed settles into top gear towing the camper at about 105km/h and will stay there , drop below that and it starts to hunt gears. I drive by the tacho when towing , not so much the speedo.
    you could always put it in sports mode and try changing the gears yourself , that would give you an idea.
    Are you looking for better ? or did you expect it to be more ?
    Cheers Ean
    Sep 2012
    Adelaide Hills
    not really sure to be honest.
    Current Cars:
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    Ean Austral Guest
    Not sure what our camper weighs but would think loaded 1000 - 1200kgs
    Standard is about 10.2 ltrs / 100ks with road tyres and no roof rack on highway.
    M/T tyres and roof rack see's me at 13 ltrs / 100ks .
    Same car , same camper , remove or change something and the fuel will alter between the 2
    D3 TDV6 6 speed .
    Cheers Ean
