Results 1 to 10 of 16
Thread: Perentie 4x4 transfer issues
    Feb 2014
    Hi all,
    My 1988 Perentie FFR has several issues that seem related however I'm not sure if they are.
    1. My transfer oil (RX Super) migrates into the gear box (1l every 2500km). This has not been an issue in the past, I just top up periodically.
    2. On my way back from a recent outback trip my transfer jumped out of high range at a traffic light in Bathurst. I re-engaged high range and drove home to Sydney, no further issues until this weekend. Drove normally until halfway home after a 40km drive and jumped out again, flat road , under acceleration, 3rd gear. It did this 3 times in 5km. I got home and tried it in low range and it is jumping out of low range as well now. Has never done that before, and it has done a fair amount of low range work. The centre diff lock appears to be working normally.
    3. After the same outback trip a hum / whine has developed on overrun in 3rd and 4th (over 70km/hr). This same hum is not present in low range, all gears.
    4. It feels like the back lash in the drive train has increased since the trip.
    I have read several posts related to the LT95A jumping out of gear (thanks Bearman and others) and will check the obvious ones (linkages, foam, lever touching the cover etc.)
    I will be dropping the oil to look for colour soon and the question is apart from the obvious bits of metal what should I be looking for as far as colour goes?
    I have checked the big nut behind the hand brake drum (intermediate shaft??) and that is tight.
    I will also take the two cover plates off to check inside the transfer once I drain the oil. I've read to check for free play on the gears and look for any damage to the gears. How do I do this and what should I look for?
    I read that the centre diff bolts have been know to work loose. How do I check them?
    Anything else I can check?
    I appreciate any advise in advance.
    Regards,
    Phil.
    Phil B
    Custodian of:
    1974 S3 swb wagon (sold)
    1978 S3 swb canvas
    48 749 '88 4x4 Perentie
    1985 County with 4BD1T
    Western Victoria
    Personally, I'd be using 20W50 oil in the gearbox/transfer case. I tried using a lower weight oil and wasn't happy with it.
    Hearing your issues, I wonder if the lower weight oil caused my oil migration problem.
    The oil migration problem is best fixed by replacing the seal. It has been discussed before in other threads on this problem. I'll see if I can find them.
    I did a temporary work around about twenty years ago that is still in place. Replace the level plugs with barbs and run a pipe (rubber hose) between them.
    Feb 2014
    Drained the transfer case oil, dark brown colour, minute flexs of copper coloured metal, I assume brass? I have kept a sample to settle overnight. No ferrous fragments, I tested with a magnet.
    Would that indicate thrust washers????
    Does the centre diff have them as well??
    Hope this helps the brains trust here give me more advise.
    Thanks,
    Phil B
    Custodian of:
    1978 S3 swb canvas
    Western Victoria
    Quote Originally Posted by Phil B View Post
    Thanks,
    Could be the thrust washers or the washers for the spider gears in the centre diff. They're the only bits I can think of but I've never had one of these gearboxes apart. Are the flecks of significant size? I usually get flecks of metal when I change the oil.
    Feb 2014
    Quote Originally Posted by Mick_Marsh View Post
    Thanks for the response Mick.
    The fleck are very small and give the oil a copper tinge in sunlight. Definitely visable though.
    Regards,
    Phil B
    Custodian of:
    1978 S3 swb canvas
    Western Victoria
    Well, I get the same but only silver in the 100" and the Perentie but they are both TRB.
    I don't do enough km in the 101s so I couldn't tell you what the oil was like.
    You should also have a TRB in you Perentie so no thrust washers in the transfer case. That leaves the centre diff spider gears. I can't see how that would be causing the transfer case to be dropping out of gear.
    Hay Point
    Phil it is going to be one of two things. Sounds like you have read previous threads on this issue so I think you will know what I am going to say. It will be either the lever fouling on the insulation under the gearstick boot or wear on the intermediate shaft itself which the hi and low range gears sit. Check the insulation bit first and if you are sure the lever is engaging the gears correctly then drop the sump off the transfer case and have a good look at the intermediate shaft gears. In particular check if the gears have any lineal movement. They should be firm and have no play in between them and also check the engaging dogs on both range gears. The teeth should be straight and not be tapered on the end that faces the selector gear (in the middle). Get someone the move the gear lever while you are under looking at it and see what is happening. Is it possible that the transfer may have run low on oil with your migration issue ? If so it is possible that the forks that move the selector gear may have worn from friction and now have a large gap which is preventing the forks from moving the selector far enough to fully engage the gear. It should be only be about .005mm gap between the rear selector fork and the gear face with the lever in neutral. The brassy look in the oil will be from the brass thrust washers behind the bevel pinions in the centre diff. Pretty normal but check for play in the centre diff while you are at it - you may have to reshim it. The centre diff bolts should be loctited and the only way to check is to take the rear output housing off and remove one of the bolts and check for loctite residue. Both the low range bolts and the ones that bolt the two halves together should be loctited. The migration issue can be fixed by loctiting the distance sleeve and output gear on the rear of the mainshaft. Also worth putting a welsh plug into the reverse gear shaft hole in the transfer as this is another known oil migration spot but this one transfers from the gearbox to the transfer case. Let us know what you find.
    Cheers......Brian
    1985 110 V8 County
    Feb 2014
    Quote Originally Posted by Bearman View Post
    Bearman,
    Thanks for your very detailed response, it is really good and exactly what I needed.
    I will inspect all the items you have mentioned this weekend and report back. Hopefully it is the lever fouling the insulation.
    Yes it did run low on two occasions and required 750ml to refill. When I drained the oil this week it was about 100ml low.
    I will let you know what I find.
    Thanks again.
    Phil B
    Custodian of:
    1978 S3 swb canvas
    Feb 2014
    Thanks for the response Mick,
    I will investigate further this weekend and let you know what I find.
    I have a detailed response from Bearman as well which I will investigate.
    Regards,
    Phil B
    Custodian of:
    1978 S3 swb canvas
    Feb 2014
    I have it in pieces and will have it check by a pro this week as I can’t see anything wrong. No play anywhere that I can see. I’ll report back
    Bear man, the distance sleeve is free spinning as you suggested causing the oil migration. I am going to fix that while the box is open.
    Which loctite should I use in between the shaft and sleeve?
    Also which loctite on the diff bolts ?
    Thanks again
    Phil
    Phil B
    Custodian of:
    1978 S3 swb canvas
