Page 1 of 7 123 ... LastLast
Results 1 to 10 of 62
Thread: Failed front wheel bearings - where did I go wrong?
    Oct 2012
    Wollongong
    To make it like this,
    No warmth in your body,
    No touch in your kiss....
    Sorry.
    Two failed front hub assemblies in 15,000km.
    Book says to crank axle nut to 490NM.
    I used a rigid bar with a 1.5M 3mm stainless pipe snuggly fitted and gave that my best.
    Even if that’s not tight enough, I’m struggling to grasp how it allows enough lateral play for the bearing to fail so quickly.
    Thoughts?
    Next one goes on with the 1300NM Milwaukee.
    Jul 2011
    Yarrawonga, Vic
    Britpart bearings ??
    Oct 2012
    Wollongong
    Negative.
    Jul 2011
    Yarrawonga, Vic
    I would not rattle gun the bearing on & IMO no need to go past 450 , The Iveco 4x4 uses similar unit bearings to the D2 , 650NM rear and 450NM up front, I have a 3/4 drive 450nm torque wrench & do the front & rears up to 450 . Ive had an original rear SKF fail at 70k (probably tightened past 650 because it took a 2m extension to crack it off) , bought a Febest bearing (similar price & reputation to Britpart) & tightened to 450 & no issues so far, 30,000km on. 650 is too much in my book.
    Oct 2012
    Wollongong
    Yeah it’s loads isn’t it.
    How long is that torque wrench of yours and does 450NM take max effort?
    First one that failed I thought perhaps I’d not given it enough, so second one I gave more..... and it failed after half the miles.
    Annoying.
    Queensland
    Why do they need to be so tight?
    My series wheel bearings are only finger tight and have a little backlash in them. Last for ever nearly.
    Jul 2011
    Yarrawonga, Vic
    Quote Originally Posted by 123rover50 View Post
    stupid pretensioned unit wheel bearings , I HATE them with a passion , give me dual tapered rollers any day.
    heres a knackered one from my Iveco, $600 in Iveco box, $160 in SKF Box $80 in Febest box
    Jul 2011
    Yarrawonga, Vic
    Quote Originally Posted by ballbag View Post
    Annoying.
    My 450Nm torque wrench is a Meter long, i'm 100kg & have to sit on it & bounce
    May 2009
    So 100 kg x 1 metre equals how many nm?
    Oct 2012
    Wollongong
