nice looking victa.....
you aint lived till you have thrown one with that sort of horsepower from forward to reverse and back again .....
the ripple thru the hull is something to die for...
After the latest V8 Vs TD5 battle in the tech forum, I thought I'd find a diesel that COULD actually beat a V8,,,,
they make an 14 cylinder IN-LINE one too---8O
Some facts on the 14 cylinder version:
Total engine weight: 2300 tons (The crankshaft alone weighs 300 tons.)
Length: 89 feet
Height: 44 feet
Maximum power: 108,920 hp at 102 rpm
Maximum torque: 5,608,312 lb/ft at 102rpm
Fuel consumption at maximum power is 0.278 lbs per hp per hour (Brake Specific Fuel Consumption). Fuel consumption at maximum economy is 0.260 lbs/hp/hour. At maximum economy the engine exceeds 50% thermal efficiency. That is, more than 50% of the energy in the fuel in converted to motion.
For comparison, most automotive and small aircraft engines have BSFC figures in the 0.40-0.60 lbs/hp/hr range and 25-30% thermal efficiency range.
Even at it's most efficient power setting, the big 14 consumes 1,660 gallons of heavy fuel oil per hour.
I cant see much wrong with that fuel consumption,,,,
:roll:
'97 to '07. sold.![]()
2007 Discovery 3 SE7 TDV6 2.7
2012 SZ Territory TX 2.7 TDCi
its well over 3000 tonnes completed,,
wonder if they just build the ship around it :?
It looks Korean - a new Kia donk maybe?
Waddaya mean find a diesel that "could beat a V8"?
Jeep Grand Cherokee:
3.0V6 CRD - 160kw, 510nm 0-100 in 9.0
4.7V8 - 170kw, 410nm, 0-100 in 9.5
(I didn't include the HEMI 5.7 ..... but the 4.7 is still a big V8!!)
