Results 1 to 4 of 4
Thread: V8 Inlet Manifold Gasket
    Mar 2010
    Can someone confirm the tightening sequence for the inlet manifold. Page 12-2-47 of the manual, reassembly point 10
    Appears as though the tightening of the inlet manifold gasket clamps after the final tightening to 51Nm of the inlet manifold bolts may result in the requirement to run around all bolts again to ensure all have 51Nm
    Is this correct.
    Below is my understanding
    Stage 1 (Initial tighten)
    Bolts
    1 - 5Nm
    2 - 10Nm
    3 - 10Nm
    4 - 5Nm
    5 - 10Nm
    6 - 10Nm
    7 - 10Nm
    8 - 10Nm
    9 - 5Nm
    10 - 10Nm
    11 - 10Nm
    12 - 5Nm
    Stage 2 - (Final Tighten)
    1 - 51Nm
    2 - 51Nm
    3 - 51Nm
    4 - 51Nm
    5 - 51Nm
    6 - 51Nm
    7 - 51Nm
    8 - 51Nm
    9 - 51Nm
    10 - 51Nm
    11 - 51Nm
    12 - 51Nm
    Gasket Clamp Bolts (Take these up in increments of 4 or 5 Nm. Not stated but I would do this)
    1 - 18Nm
    2 - 18Nm
    Stage 3 - (Final Tighten/Check)
    1 - 51Nm
    2 - 51Nm
    3 - 51Nm
    4 - 51Nm
    5 - 51Nm
    6 - 51Nm
    7 - 51Nm
    8 - 51Nm
    9 - 51Nm
    10 - 51Nm
    11 - 51Nm
    12 - 51Nm
    Mar 2010
    Ok
    The plan will be as follows
    Stage 1 - Bolts 1,4,9,12 - 5Nm All others - 10Nm (in numerical sequence both 5 and 10Nm)
    Stage 2 - Gasket Clamps to 18Nm
    Stage 3 - All in sequence to 25Nm
    Stage 4 - All in sequence to 51Nm
    Wait 15-20 mins,
    Stage 5 - Check all to 18 or 51Nm respectively
    May 2003
    On The Road
    After doing 3 sets of heads in 4 years, on the last set I said glue everything. EVERYTHING.
    I hope the damn things dont leak on you Andrew,,,
    Mar 2010
    Well, if they leak I can only blame myself.
    I have removed the heads but they look to be in very good condition. As well as the cylinders etc.
