Results 1 to 10 of 32
Thread: IT Weirdness
    IT Weirdness
    My MY18 D5 HSE with Touch Pro and the Meridian stereo does some weird, random things.
    Reverse camera does not turn on when reverse is selected.
    Reverse camera does not turn off when drive is selected.
    The front parking sensors do not turn on when approaching a wall when parking.
    The USB cannot be accessed or selected or generates an error message (Corrupted, need formatting, etc).
    The connection to my iPhone with InControl apps mostly doesn't work. In fact I've given up trying to use it.
    The stereo reverts back to a radio station on start up and not to what it was doing on shutdown (USB, CD, etc).
    On start up, "Media not available" appears for seconds to minutes depending on the car's mood.
    The SIM card is not present or is not compatible.
    Touching the icons on the screen does nothing.
    There's no rhyme or reason to these things and most of the time things work as advertised. When things do go wrong the simplest solution is to exit the car, lock it and count to 60 which is reminiscent of the D3.
    I know there's a update available but I'm interested if anyone else is having these issues.
    Mark
    Nov 2016
    Eltham, Victoria
    Not here mark. I know they have phase 4 update so you may want to see if you can get that installed.
    Oct 2011
    Hunter Valley
    I've only had the car a couple of hours but have noticed the "reverse camera does not turn on when reverse is selected" once.
    They did not install the phase 4 update.
    Ron
    2016 D4 TDV6 Corris Grey
    2018 D5 TD6 SE Silicon Silver - gone
    2011 D4 TDV6 2.7 Indus Silver - gone
    IIDTool BT
    Aug 2017
    Tamworth
    Phase 4 updates
    Just got discovery back after service. Phase 4 updates seemed to have fixed mine. Never really had an issues except for phone calls sometimes would hang up, but system did not recognise it and could not use screen. Reverse camera did stay on extended previously but update seems to have fixed this. Might be worth checking it out first.
    Dec 2011
    Bundeena
    I think the parking sensor one is by design. If you are driving right into that spot after having been driving enough for the sensors to turn off then they won't turn on until a gear selector change to reverse or park has been done (think driving in traffic). You could manually switch them on using the button as you pull into the parking spot.
    Sean
    Oct 2011
    Hunter Valley
    I think so is not turning off the rear view camera when selecting drive. There's a 5 second delay.
    Ron
    IIDTool BT
    NSW SW Slopes
    Quote Originally Posted by SBD4 View Post
    I hadn't thought to try this on my L322 where I often would like the front sensors to operate.
    Phase 4 update done yesterday. The home screen is completely different and the nav now shows the speed limit. We shall see what happens with the tech glitches.
    Oct 2011
    Hunter Valley
    Phase 5 will be out soon if you still have issues. It is promised to fix lots of issues, but no doubt introduce others...
    Ron
    IIDTool BT
    Jul 2018
    BALMORAL
    I had phase 4 update a couple of weeks ago. It has been faultless ever since. I used to get Bluetooth drop outs , no Spotify data (Apple music worked though), no radio information on the screen and even a full radio lock up where no buttons worked and I couldn’t turn it off.
    Switching between Bluetooth devices was also slow and difficult
    Everthing seems to be fixed now and it is working 100%. The new menu structures are also simpler and thing like Bluetooth have been brought to the front to make it easier.
    if you haven’t got the update I suggest to get it
