Results 1 to 9 of 9
Thread: Discovery 2 rear passenger door latch/handle adjustment
    Nov 2008
    Hi all,
    Way back in 2012 I bought by Disco 2. It needed replacement door actuators on both rear passenger doors. I ordered new LR ones and fitted them. I then found that both doors required a real big heave on the outside handle to open either door. I managed to adjust one by adjusting where it strikes on the body but this is still not ideal. The other problem is that neither door has been able to open from the inside no matter how much force is applied to the interior handle. I got excited when I watched a video on how to adjust the front doors by twisting the linkage on the thread, but the rear doors have no such adjustment. There is simply a linkage with no plastic threaded piece. Now I've dropped the linkage down into into the door at top of the arch and do you think I can see it or get it out? No way. I've changed water pumps, transmission hoses, and rebuilt an alternator on this thing, but these doors have been my biggest challenge. Any ideas appreciated.
    Jan 2013
    WA
    Had the same problem when i did mine could not find until i stuck a wire coat hanger or same down the crease which forms the arch in the rear door, once retrieved i stuffed a rag there so if dropped whilst refitting it could be got at easily. Put a bend in it to shorten its travel will help with opening the door.
    Cheers tt
    D2 2004 TD5 Classic
    Nov 2008
    Cheers. I had ideas of putting a bend in the linkage (once I find and retrieve it). Now to work out a solution for the interior handle.
    Quote Originally Posted by thai_tiger View Post
    Dec 2009
    Baldivis WA
    Quote Originally Posted by coops71 View Post
    Hi all,
    Sounds like the child lock is on. Small lever near the door catch.
    2014, MY14 Discovery TDV6, Fuji White (2018-Now)
    2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
    2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
    Free Again Thanks Dan
    Quote Originally Posted by kelvo View Post
    Doh
    Nov 2008
    I wish it was that simple!
    Nov 2008
    I had a bit more of a play with the door today. I've shortened the linkage to the outer handle. This seems to have made a substantial difference. Still no joy with the interior door handle. Any ideas why the child lock switches on as I pull the interior door handle? I'm really baffled.
    Nov 2008
    So I found the problem! Several years after installing new actuators and never being able to open the doors from the inside it appears that both actuators were put together on friday afternoon. I started pulling the actuator apart with a focus on the safety lock. One of the parts was placed wrong. I really can’t see that I’d forced these myself as I took my time making sure nothing was jammed on installation. Inside handle now works perfectly, with the added bonus of the outside working even more easily. See pics below. The correct fitting is the one with the arm fitting inside the slot.
    Jan 2017
    Thornlie 6108
    Congrats! Discovery 2 rear passenger door latch/handle adjustmentDiscovery 2 rear passenger door latch/handle adjustment
