Microcat for part numbers.
I’d be ringing a wrecker for the sensor.
Hello,
Well tracked down a faulty inner left rear parking sensor.... LR want $600 to replace! year right!
anyway, looking around for a single sensor.... best locally (WA) is $170. nice, that is a solid price! Can anyone point me in the right direction for purchasing one? - also confirming part number is LP038533P ?? for 2011 Disco 4 HSE
Also assume bumber off to get the sensor?
on another front - I bought an electronic copy of the workshop manual...but noticeably absent part numbers! any help on this one?
I've seen in another thread on here that the front sensors are commonly used across many models and you can get the Ford version much cheaper.
I'll assume the same applies for this rear one. Looking in Microcat the Assembly identifier for the LR038533 rear sensor is 15K859. If you search for that you'll find Ford rear sensors that look identical (the connector seeming to be the main variation) for much less money.
Edit - this one specifically states compatibility with D4: PDC Parking Sensor For Land Rover Range Rover Sport Discovery 4 Freelander 2 826962974674 | eBay
$10 !
David
Everything is easy when someone else is doing it
MY14 SDV6 SE Corris Grey
Compomotive 18s : D697s : Traxide DBS : LLAMS : ARB compressor : IC-455
Rhino Platform : GOE compressor, Tx & front bash plates, deluxe sliders
 Master
						Supporter
						Master
						Supporter Wizard
						Subscriber
						Wizard
						SubscriberPart number is actually LR038533.
Various quality/price parts available
Low https://www.brit-car.co.uk/product.p...rover_sport___
Medium LR038533 | PARKING AID SENSOR REAR - L322 RANGE ROVER - EVOQUE - DISCOVERY 4 - RANGE ROVER SPORT - | Allmakes | | Britcar (UK) Ltd
High LR038533 | PARKING AID SENSOR REAR - L322 RANGE ROVER - EVOQUE - DISCOVERY 4 - RANGE ROVER SPORT - | Land Rover | | Britcar (UK) Ltd
2014, MY14 Discovery TDV6, Fuji White (2018-Now)
2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
