Results 1 to 10 of 18
Thread: Discovery 1 kickdown cable replacement
    DAMINK Guest
    Ok so turns out i have to change my kickdown cable on the old girl.
    Thought it would be a pretty simple job! But after doing a few searches here and on other sites it seems i have to pull the box apart?
    Can anyone give me a reasonable idea of whats involved and if there is any way to make it easier, like pulling the shifter off and accessing from there perhaps and not pulling the box apart is my hope??????
    Any advice would be greatly appreciated thanks.
    At this point i am going by this video as the procedure needed.
    Sep 2013
    Darwin
    12.74 MB
    Changed a kick down in a D1 Tdi300 many years ago. From memory sump, filter, and valve plate off - not hard, easy refit, just messy.
    Hardest parts were getting fingers in tight recess to unhook the pivot slug (the cylinder pressed to the end of the wire), and equally vexing getting the new one hooked; then seating the new rubber boot seal properly to the casing.
    DAMINK Guest
    Quote Originally Posted by workingonit View Post
    Yea im looking forward to it mate. Had a few other things to do today so did not get it apart but have ordered parts and will finish it tomorrow.
    Not looking forward to the fiddly bits. My stumpy fingers and carpel tunnel really make for fun and games some times.
    Jan 2008
    Quote Originally Posted by DAMINK View Post
    Done it many times. It is messy. To reduce the mess:-
    (a) let it sit for a couple of days before pulling the valve block, as it will drain slowly.
    (b) only remove the large headed torx bolts, otherwise you are in for a world of pain if the valve body separates.
    Damien
    St Helena,Melbourne
    4.28 MB
    I printed off a copy from rave of the valve body and circled the bolts I need to remove, used gloves and clean rags but did it on my front lawn.
    Worse part was re routing the cable up over the trans.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    DAMINK Guest
    Thankyou lonerangie.
    I will do the same.... ie print rave to make sure. The video does say there slightly darker bolts?
    Yea it seems the aftermarket ones are slightly different. The cables i mean and do require some tongue twisting to work out.
    I look forward to learning it.
    DAMINK Guest
    I hunted this pic down off the rave cd and decided to copy it up incase anyone else in the future needs it.
    Appears there is only 13 bolts to undo to get the control unit out.
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Just remember cleanliness is paramount with transmissions, any dirt. lint fluff etc can cause you grief later
    DAMINK Guest
    Well the job went smoothly. Not a bad job to do actually if you like the red stuff.
    Took it for a drive and had a tranny line i made up to work around the winch let go and split at the clamp. Clearly not good enough hose so gotta get me some better stuff tomorrow and fit that.
    Jobs never ending on this car i tell ya.
    Apr 2016
    Country Vic.
    Good to hear that the cable job went well.
    Have it locked into the back of my grey matter if the time comes and I have to do mine one day.
    I vaguely remember a post you made re a trans line, and using clamps and stuff, and I thought to myself that doesn't sound right.
    Lots of chatter within these pages re trans lines and the need for proper high pressure stuff as the trans can produce over 100 psi of pressure or something to that effect.
    More of that chatter in the D2 area due to the design of the (quick)connectors to the trans cooler ... and maybe they rub on the engine block ... or something like that. Not so much a problem on the D1.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
