Results 1 to 9 of 9
Thread: Wing top/ chequer plate removal
    Jun 2017
    Brisbane west
    I want to remove my chequer plate wing tops to replace them, but the silicone holding it down wont let go and im worried about trying to pry it too much. Wondering if anybody has had the same struggle and found a way to get them of without damaging anything?
    Very strong fishing line...
    There’s also a removal fluid, but you should be able to get away with Fishing line (wrap ends around dowel to enable some leverage) and some diluted dish liquid.
    Oct 2013
    Richmond, NSW
    Quote Originally Posted by 200defenda View Post
    Hey 200defenda, if you can remove them without too much damage i would be interested in them for my 300Tdi project :-)
    Travelrover
    Adventure before Dementia
    2012 Puma 90 - Black
    1999 Td5 110 Ute - White
    1996 Tdi 300 Wagon - White
    Jun 2017
    Brisbane west
    Awesome thanks mate ill give it a go, see how i get on. Travelrover if i can get them of in ok condition, you can have them no worries. Ill let you know.
    VladTepes's Avatar
    Bracken Ridge, Qld
    How'd you get on?
    You sure it's silicone because if it's a structural panel adhesive you're going to be out of luck !
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Jun 2017
    Brisbane west
    Yea not so good i cant get them off there stuck on there pretty well.its hard to say whats holding them on, from what i can tell it looks like silicone but could be something else considering how well there on.
    VladTepes's Avatar
    Bracken Ridge, Qld
    Can you get under it at all on the sides/edges, or is it stuck firmly together?
    gone
    1996 Discovery 1
    current
    Lebanon
    If it is structural glue, your best chance is to use wire saw. A putty knife will be handful to work on the checker plate edges,.
    In both cases care should be taken to insure the paint work is not scratched by the cutting action.
    Dec 2008
    Tewantin, Qld
    It may well be a polyurethane sealant / adhesive, they will resist the fishing line trick a lot more than silicone.
    Urethane generally softens above 80 Celsius, you could try pouring plenty of hot water on it to soften it, the hot water shouldn't damage your paint work.
    Cheers Glen
