Results 1 to 4 of 4
Thread: Shock absorbers, whats the difference between standard and heavy duty ?
    Feb 2018
    Adelaide
    Greetings all knowing Land Rover gods,
    I'm getting to the point where I'm putting the Maggie back together. I've noticed two different sets of shocks available and was wondering if anyone has had much experience with the two.
    Land Rover Parts - 5: SHOCK ABSORBER (FRONT) 88" 1954-84 HEAVY DUTY + 109"/109" V8 STANDARD
    Land Rover Parts - 5:SHOCK ABSORBER (FRONT) S1 1954-58, S2+S2A+S3 SWB STANDARD
    Is the ride height different between the two ?
    Do I need special bushes for the heavy duty ?
    Will they be considerably stiffer than the standard ?
    Kim
    P.S. just wanted to say thanks for all the help that has been provided so far, its been great.
    Narre Warren South
    Quote Originally Posted by Kimsl70 View Post
    Is the ride height different between the two ? No
    Do I need special bushes for the heavy duty ? No, should bw supplied with bushes anyway
    Will they be considerably stiffer than the standard ? Maybe
    I'd contact the seller and ask the question.
    The HD are bigger diameter so larger oil capacity. As a shock absorber works it generates heat which causes the oil to thin and the damping is reduced. A bigger capacity of oil should mean more distance before the damping is affected.
    They may be made from thicker material, have stronger welds, better damping etc. Unfortunately you probably won't know till you get them.
    What brand are they ? No mention on the website......
    Finally, what are you going to us the vehicle for when it's finished ? Do you actually need HD shock absorbers ?
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Melbourne, Vic
    Kim
    I don't have any direct experience with those you're looking at, but typically heavy duty shocks are shocks that can dissipate the heat better than standard. This allows for the driving on poorer road conditions with lower risk of performance of the shock dropping (potentially failing).
    Performance wise (I.e. ride height, are they stiffer etc) - I'm not sure, however I would expect that if you're planning on needing the heavier duty, the bushes etc should be uprated to in order to help manage the risk of them failing under the tougher conditions.
    Current: ‘16 Disco Sport (7seater) aka « Family Bus 2 »
    Sadly Gone: '77 RRC 2 Door aka "Beast"
    Gone: '92 RRC Vogue SE aka "The Family Bus"
    Long Gone: '99 Td5 Defender aka "The TANK!"
    Feb 2018
    Adelaide
    Thank you
    G'day guys,
    Thanks for taking the time to reply, I appreciate the input. In answer to your questions, Maggie will be used on our farm in lieu of a quad bike (but not flogged). Typically moving some cattle, dragging a chicken caravan, moving apple crates and teaching our kids to drive. So whilst the farm is undulating, we won't be doing any rockhopping, but we will be on unimproved country. I think I'll give the guys a ring to see what they say.
    Kim
    'Maggie' 1960 Series 2 88 2.25 petrol 3MB
