Results 1 to 6 of 6
Thread: Lucas Windscreen Wiper Motor Refurb
    Jan 2011
    Is there anyone in ACT / NSW that can refurbish the independent LUCAS wiper motors as fitted to 1960's Series IIAs? I have attempted to get mine working but each have issues - namely the on / off switch on both is not working correctly (very slack) and one has an electrical short.
    I know I could probably run through more of the helpful tutorials online to fix these issues but my preference is to get someone that knows what they are doing!
    Cheers Jack
    Narre Warren South
    More importantly it needs to be someone who has access to the spare parts to fix it.
    You probably need to find an 'old' auto electrician.
    Sorry I can't help.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Hobart Tasmania
    Not sure if I can help, but I have a few videos on how I refurbished mine. They are quire easy to do, but of course I didnt have any electrical issues.
    Carlos
    1963 Land Rover Series 2a 88
    chewthecud Guest
    chewthecud
    I had the same problem with the wiper motor on my 1960 truck cab and bought a generic after-market version, sold as fitting a Land Rover. However the windscreen base on the older Landy is too thick, rendering the threaded locator around the shaft of the after-market option too short. By chance I was in an autoelectrical shop and noticed they did small motor rewinds so gave them my old one to repair. Apparently if the motor is burnt out (smells burnt) they can't be rebuilt but most other failings can be fixed. The overhaul on mine cost $250 and it looks and works like new. The repair crowd I used was Clay's autoelectrical - unfortunately in Adelaide. But it can be done.
    Aug 2020
    Victoria Australia
    Thumbs up Wiper Motor Refurb
    Quote Originally Posted by Cap View Post
    Hi thankyou for your video. Could you tell me what grease you use to lubricate the wiper motor please.
    Thanks,
    danniboy
    Hobart Tasmania
    I used what I had on hand, but pref would be a grease that is good with plastic and moisture. Cant remember if it was marine grease or not...
    Carlos
