Results 1 to 3 of 3
Thread: "Pop" on shutdown?
    Mar 2007
    Warwick Qld
    "Pop" on shutdown?
    Took the Limo for a run to see if I've cured the coolant issue (dumping a heap of coolant after a run around the block). Cautiously optimistic about that, after (hopefully getting rid of an airlock).
    After the test run, pulled up in the driveway and shut down, and got a "pop" from the engine as it stopped. Started and shut down again, same result.
    Any clues from the brains trust?
    PS. It's a 4.6 GEMS.
    1999 Disco TD5 ("Bluey")
    1996 Disco 300 TDi ("Slo-Mo")
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    is it a pop coming from the intake? like unburnt fuel back firing thru the intake.
    Mar 2007
    Warwick Qld
    Sounded a bit like that, but seeing I haven't disturbed anything except the coolant expansion tank (lifted it about 45mm), though I did have to unplug the connector under it to give me some room. They seemed to plug back in OK, though.
