Results 1 to 10 of 11
Thread: Our recent caravan trip
    Jul 2015
    Bowen
    In another thread I posted that while we were away a grinding noise developed in the rear. This post is more like a report on the trip in general with a few questions about best practice when towing. On the highway we kept up to around 100kph whenever possible other than on empty roads when I would cruise at about 95. Rest of the time flowed with the traffic. Anything less than 80kph I'd drop her into 3rd as we slowed and got it to lock whenever possible. Hills and grinds also. She sailed up Cunningham gap between 70 and 75kph in locked 3. I am not in the habit of using Sports mode when towing. Should I?
    [As an aside the S/M lights on the dash are not functional, neither is the LCD display for PRD321 and the dash does not light up when the driving lights are on. Is this likely to be fuse/fuses? At present I only know we in normal rather than Sports mode by the way she behaves. Our dog sometimes steps on the button.]
    I have heard that one should not tow in drive, but rather 3, locked. This is OK but anything over 85kph and the revs are in the 3000 and that's not comfortable for sustained driving to my ear. Also its unreasonable to other road users. I think we've all seen the queue of traffic banked behind a slow caravan and who enjoys being pushed along by a B-double up their clacker?
    But what is best for the car? Perhaps it's a compromise of best practice for traffic conditions and the car has to put up with it.
    Some few 10,000s kms ago a screeching whistle developed when under power: sounds a bit like a slipping PS belt or a dry bearing. I checked everything for wobbly bearings, slipping belt but found nothing. I let it go, thinking it would let me know eventually. Not good practice I know. Perhaps the turbo on its way out............ Well, she still does it. Car has plenty of power. It's loud enough that pedestrians stop and look. Any suggestions please?
    Thanks,
    Pete
    Ferntree Gully, Vic
    That whistling sound will most likely be your exhaust manifold is warped. Check for black soot marks around the bolts and it will tell you if it is or not.
    Perth WA 6149
    Regarding the missing dash lights, checking fuses is always a good starting point. Do the red position lights show up on the gear shift?
    Other possible culprits are wiring and dirty connectors. A dirty xyz switch on the transmission will also result in the LCD position indicators not showing and the wiring from it over the back of the transmission can also chafe. In my experience though only some of the positions disappear in these cases and doesn’t explain the lack of S&M lights.
    Finally a left field idea, but has the instrument cluster been accidentally reprogrammed to a manual transmission configuration? Weird I know but it happened to me when I changed the central locking on Charlie to one click door opening, using the nanocom. Threw me for a bit as I was missing all the auto related lights in the dash. Nanocoms can be a bit random at times.
    Steve
    Jul 2015
    Bowen
    Quote Originally Posted by Rok_Dr View Post
    Yes
    Steve
    That's interesting as I did just that a while back.. Will have to check that out - thanks
    Pete
    May 2003
    On The Road
    Hi Pete,,
    First question is how much does the van weigh,,
    you have the right idea not towing with the Auto unlocked,,,
    Jul 2015
    Bowen
    It's a Jayco poptop. With a full tank of water and set for the road with a few days in the porta-loo I'd guess a bit over 1 tonne. Should be almost insignificant for a mighty D2 but sure knocks back the fuel economy. Over the 6000+km trip averaged 8.2 km/l with maybe 1000km without the van. At home I'm displeased if it returns less than 10 km/l. Then I wonder how a Hilux would go....... I love the TD5 motor.. But then it has not gone wrong yet!
    Perth WA 6149
    That's pretty good fuel economy Pete. My all up average over almost 60k is 12.8l/100km, including van towing duties, where I get 15l/100k towing a 1800kg poptop.
    It will be interesting it hear how you go with the dash lights and whether it ends up being the same problem I had.
    Steve
    Jul 2015
    Bowen
    Hi Steve, don't get me wrong - I'm not complaining, just saying, tho' I could have said it better. Someone said once that it's not so much the weight you're pulling but rather that you are actually pulling another set of wheels down the road. I have not done long trips with our box trailer but I do notice a dramatic change in fuel usage even with that little thing behind. Then there is there is the windage......... The last leg of our trip hope was into a stiff breeze and by golly it chewed up the juice.
    Presently engaged in another project but will try and find time to chase up the Nanocom/dash lights possibility.
    Pete
    Jun 2013
    Augusta WA
    Quote Originally Posted by Tinggu View Post
    Pete
    It's fine to tow in Drive as long as you are at speed to lock up the TC ie; 80+. Rule of thumb is third locked up cruising to 80 and for hills, cruising on the flat above 80 Drive locked up. Nick
    Jul 2015
    Bowen
    Thanks Nick. That's just what I do. Glad to be doing the right thing for a change!
