Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: Hi lift jack points - D4
    Jan 2017
    Hi guys,
    i have 2015 D4 TDV6, with factory side steps but no front bullbar
    or rear steel bummer. I’m off on a desert trip soon. It’s been suggested I get a hi lift jack.
    Any tips/advice on the best jack points on D4 for the hi lift jack?
    My guess is the rear square towing point. Also, Can you jack on the side step?
    Or
    are there better solutions for recovery, etc
    May 2006
    Woolgoolga
    Why would you get a high lift jack?
    St Helena,Melbourne
    1.13 MB
    They might be OK for old yanky trucks but no good on a modern 4wd.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Tangambalanga
    For the weight alone of a HL Jack,, they're not worth it. Although they can be used as a winch, but not much good for lifting a D4,, unless you have all the steel bars, including the rock sliders. I would suspect your "side steps" are probably alloy based, and therefore not strong enough for a lift anyway.
    I would advise having some thing like Treads, or MaxTracks for use, and if you travelling with someone, a snatch strap. The D4 without a trailer behind it will be exceptionally capable on its own. However, as I found out doing Googs Track last year, a trailer greatly diminishes its versatility so to speak if your doing sand hills.
    You can hit sand dunes doing quite fast speeds to start with, which will get you over most times, but for me, between the trailer and 20" rims, I struggled big time.
    Hope this helps
    Lemme guess - the person suggesting it is a Cruiser/Patrol owner Hi lift jack points - D4
    No need for such devices, a pair of Tred Pros and a good shovel will be far more useful.
    Add a compressor and tyre gauge and your good to go (almost)...
    Feb 2005
    Yep leave the hi-lift jack at home......
    Tyre pressures
    Compressor
    Long table shovel
    Maxtrax if ya must
    Get No. 1 right you won’t need 3 and 4
    LRD414's Avatar
    Oct 2014
    Another vote for shovel/Maxtrax/compressor being far more useful in the desert.
    A better option for jacking is to get a good bottle jack with 200mm extension.
    Add to that a solid jacking plate of say 300x300 for the sand.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    I wouldn't put a hi lift jack under any vehicle I own. Leave it painted orange or yellow and bolt it onto something to look tough, like your garage door. Now let your tyres down properly so you dont get bogged and if you need to jack it up for tyre change , buy a good hydraulic bottle jack that weighs the same as the hi lift and a good lump of timber to support it...it'll still take up less room.Trying not to be too facetious here but I don't like the things.
    Jun 2008
    Quote Originally Posted by Chops View Post
    Hope this helps
    Chops , when did you do Googs? I did it last year last week in August , north to south.
    Tangambalanga
    We did it after the Easter meet at Melrose.
