Thread: EGR valve blocking
    Jun 2018
    Perth - WA
    EGR valve blocking
    Hi guys. Looking to block off the egr valve (s) can’t see the benefit of putting burnt **** into an engine. I have been told that I can get it done electronically, as part of a performance “chip”/ upgrade. Whilst this sounds great the $1200 isn’t quite on the radar yet. Can it be done with blanking plates? Anyone done it? Thanks.
    St Helena,Melbourne
    4.28 MB
    If its an 07 or earlier you should be able to use a blanking kit.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jun 2018
    Perth - WA
    Thanks but it’s a sdv6 2014. Any ideas?
    Dec 2011
    Bundeena
    Quote Originally Posted by phk View Post
    I don't' think you'll be able to use blanking plates. This has been something people have been trying to do for years on these engines - it's not been achieved.
    Edit: there is a bloke in WA who was working on a mechanical replacement that fools the ECU into thinking the EGR is still inplace. Not sure on where he is up to with it. From memory there were some issues to iron out.
    Sean
    Jun 2018
    Perth - WA
    Quote Originally Posted by SBD4 View Post
    thanks. wonder if it can be done electronically (with a nonocom etc) like I said can be done as part of a full re chip but $1,200 is a bit steep at the moment
    DiscoMick Guest
    I assume you're aware it will make your vehicle non-compliant with ADRs so, in theory, unroadworthy. Your choice, of course.
    Feb 2010
    Mount Martha
    I always get an ECU tune done on my vehicles which include an electronic EGR blank.
    It's not 100% legal, but then who would know?
    They always keep your original tune on file, so you can swap it back at any time.
    Cheers, Craig
