Results 1 to 10 of 17
Thread: Transfer case filler plug
    david7307 Guest
    I am going to check the oil in my transfer case this week , and from memory of last time, its a hard job getting filler plug out, i used a half inch drive head to remove it , can you replace plug with a standard bolt like plug and just use a spanner to undo it ,and if so what size of thread is it
    Jun 2013
    Augusta WA
    Quote Originally Posted by david7307 View Post
    I did mine last week with no problems, I don't think you will be making it any easier with a bolt. Nick
    Oct 2012
    Wollongong
    Use a 5/8” extention bar and ratchet with 1/2” adaptor on the end of it. Easier to get it square than using 1/2” gearTransfer case filler plug
    Crafers West South Australia
    Pretty sure it's 3/4" BSP, any plumbing shop should have something suitable in brass. But I bet the original plug would seal better as it's made for the job.
    Jul 2014
    PERTH, WA
    Hi David,
    I have also had difficulty with this (every time) - my transmission brake housing gets right in the way.
    In contrast to the 5/8 inch idea, I think a 1/2 inch sq drive universal with male ending works pretty well.
    Just put the 1/2 inch male ending into the square recess in the plug.
    Andrew
    armidale
    Quote Originally Posted by ballbag View Post
    I’m guessing you meant 3/8 not 5/8 but anyway that’s easiest way I’ve found too
    NSW far north coast
    Just use a long 1/2" wobble drive, gets you past the parking brake drum easily.
    Free Again Thanks Dan
    Quote Originally Posted by rick130 View Post
    x2
    Apr 2016
    Country Vic.
    I think the brass diff filler plugs are the same.
    Search for discovery brass diff plug .. or something similar you get many hits.
    Same brass pugs are used on the D1 radiators and on some of the D1 engine bleeders.
    They're a better replacement plug type for the plastic ones LR fitted originally.
    Some D1's use those 1/2" drive filler plugs on the diffs too.
    Can't remember the size of the hex head tho .. something like 7/8ths or similarly large so if you go that way, just make sure you have a ring spanner to suit.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Oct 2012
    Wollongong
    Quote Originally Posted by mrb505 View Post
    Yeah, that’d be the one.
    I often wonder whether the designers/engineers were really clever and designed things like this with just enough room, or did they not think if it and got lucky that there just happened to be enough. 🧐
