Thread: TD5 auto to manual conversion.
    Sep 2010
    The Hills.
    152.79 MB
    I'm over trying to find a decent, affordable auto for my car. It occurred to me that I have a low Km Ashcroft suffix L R380 in the D1. Am I correct in thinking that the only difference between a 300Tdi box and a TD5 one is the input shaft and bellhousing?
    Obviously the conversion is a much bigger task than just those things, but there is no point considering it if the actual box can't be made to fit. Clues, anyone?
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Sep 2010
    The Hills.
    152.79 MB
    Also, does the ECU need to be changed?
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Oct 2007
    Brisbane West
    M8 from memory the BCU needs to have a clutch input signal for the Hill Decent Control to work. Apart from that should be OK I THINK. As you note they are both R380. Cheers
    Jul 2014
    west of Transylvania
    Quote Originally Posted by johntins View Post
    Better yes cos the auto ECU doesnt have the clutch switch input link in it and needs a remap to manual fuel map too.... a manual ECU is cheaper and works as it should ... btw the clutch switch input is not mainly for HDC it's for cruise control and gear change surge damping which is important
    NSW far north coast
    And the 'L' R380 is the TD5 'box (apart from the input shaft)
    It's much stronger than the earlier 'J' suffix 'box.
    FWIW the equivalent 'box for the Tdi siren in 1998 was a 'K' suffix. Dave Ashcroft said that they are dimensionally identical to the L and they treat them the same when rebuilding.
