Results 1 to 10 of 27
Thread: Which Discovery 4 / LR4 - 3.0 TDV6 or 5.0 V8?
    A RO 95 Guest
    Hello all, I am based in Germany and I am looking to buy a Discovery 4 / LR4.
    I have done a bit of research and I am still not sure whether to go for a locally sourced 3.0 Turbo Diesel or import a 5.0 Normally Aspirated Petrol from the UAE. Including transport and import of a 5.0 from the UAE, the cost of both alternatives should be very similar.
    Here my Pros / Cons list
    5.0 Petrol
    Pros
    Currently no foreseeable restrictions entering German cities
    Less vulnerable to variable fuel quality
    More relaxed cruising on the German Autobahn
    Cons
    Appalling fuel economy
    Less torque
    No heated seats
    3.0 Diesel
    Pros
    Better fuel economy
    More torque
    Cons
    Potential ban from entering cities here in Germany
    Fuel quality and possible problems with DPF and ECU
    Availability of Diesel fuel for private vehicles in some East European / Asian countries
    As you can see, I currently have found more pros for the Petrol than the diesel, but the 2 Pros that I have for the diesel are very important points and more immediate as I am not sure when and how often we will be travelling more further a field!
    A point on which I am unsure at the moment is reliability:
    I have read quite a bit about engine and crankshaft failures with the 3.0 Diesel.
    How wide spread are the problems, how seriously should I take this point?
    How reliable are the supposed improved post 2012 diesel engines, and from which VIN?
    I have not found much information on the reliability of the 5.0 normally aspirated petrol engine, I take that this is due to one of two reasons:
    1) There are no known major problems – people are more likely to write their opinions if they have something to complain about!
    2) Fewer vehicles on the road with this engine, and those on the road generally have lower mileage / are not used as hard as the diesel engine versions.
    What are the known weak points of this engine?
    Brisbane, Queensland
    From what I’ve read diesel cars are getting more and more regulated in the EU & UK, and will be excluded from more and more cities.
    The 3.0 tdv6 failure seems to be rare, but I have read about such a failure even on a late facelift D4 before it was due for its 1st or 2nd service (can’t recall which one). A failure seems to be completely unpredictable. Failures have also occurred on the tdv6s fitted to the L405s.
    The 5.0 V8 na seems to be a very reliable motor, which was also fitted to the L322.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Hornsby
    Quote Originally Posted by A RO 95 View Post
    5.0 Petrol
    Pros
    Cons
    Less torque
    No heated seats
    3.0 Diesel
    Pros
    Better fuel economy
    More torque
    Cons
    If it was for me I’d get the V8 but I’m biased I bought a D3 V8 last year and love it. Biggest problem is fuel economy, which would be a concern in outback Australia. I’m fitting a long range fuel tank to at least minimise the problem. Objectively for me I was buying a car that’s over 10 years old and thought a simpler engine setup would provide less risk. No DPF, EGR or twin turbos. Having said that I’ve had 2 issues I didn’t anticipate, a bad injector and rusted radiator connector that needed a full replacement.
    Randy
    Sep 2012
    Adelaide Hills
    in a small country like germany, fuel economy is a non existent issue. haha
    petrol engines also easier to fix
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Kingston, Tassie, OZ.
    Definitely pick the v8 5.0.
    In fact, for a petrol engined big vehicle they are very economical. Remove the potential dpf, egr and turbo costs from the equation and you may very well be ahead in total outlay after some years
    Jun 2010
    Central Coast NSW
    Plus you have that SOUND! That's a big pro for the V8
    Quote Originally Posted by Disco-tastic View Post
    .... my 4.4 diesel makes ALL the right sounds though 😁
    Mmmmm🤗😍
    YouTube
    NSW SW Slopes
    According to the L322 MY11 brochure, the na 5.0 gets to 100 kph in 7.2 secs compared to the 4.4 in 7.8 secs. The 4.4's higher ratio diffs probably don't help get it off the line quickly.
    Dec 2009
    Ranelagh, Tasmania
    I have read of a few problems wth the V8. Water pumps are known to fail. Early ones had aluminium in the cam chain tensioner guide where the hydraulic tensioner pushed and could wear giving noisy cam chains and because they are DI they can get carbon build up on the back of the inlet valves.
    Saying that my 2010 gave no problems in 210K except for the throttle body needing cleaning to clear a persistent MAP error.
    They are very quiet and well muffled, I wish my RRS SCV8 was as quiet.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
