Results 1 to 10 of 14
Thread: Disco 5 wheels
    kreddy Guest
    Disco 5 wheels
    I am getting my new disco 5 which is coming with 22" wheels. I want to change it for off-road tyres...so was planning to see if the Disco 4 19" wheels with 255/55/19" tyres fit on the new disco 5.
    St Helena,Melbourne
    1.13 MB
    What about a set of Tuff Ant steel rims ?
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    NSW SW Slopes
    255/55R19 will lower the drive ratio which is usually undesirable. 20" fitted with 275/55R20 provides quite a few tyre options.
    Oct 2012
    They don’t fit new RRS so doubt if will fit new Disco.
    Jan 2013
    Quinn's Rocks W.A
    Better off ordering with the 20inch wheels if you can, a lot more tyre options.
    the Tuff Ants do have 18 inch Steelies on the water, and Gordon has the Compo”s you can purchase for the D5 already I believe.
    jack
    Jack
    MY 2018 D5 HSE LUX
    MY 2013 D4 HSE ( gone with 155,000km )
    MY 2010 D4 SE ( gone with 100,000km )
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by PerthDisco View Post
    Pretty sure they are advertised as fitting D5's. Yep, here is the link Steel Wheels now available to Order for Discovery 5
    1974 VW Kombi bus
    kreddy Guest
    thanks for that. But what ever 20" tyre am looking at all have low profile tyres. that is why wanted to go to 19". well if there is no option then have to go with the 20"
    kreddy Guest
    Quote Originally Posted by GP1200 View Post
    jack
    I think I should try and get 20" as going to TuffAnts 18" am not sure if its going to cause an issue with the warranty; just because landrover clearly says 18" is too small for the new disco.
    Oct 2011
    Hunter Valley
    +1
    That's what I did a while after placing the initial order and found there to be not much rubber available in 255/60R19, change the wheels from 19" to 20".
    Ron
    2016 D4 TDV6 Corris Grey
    2018 D5 TD6 SE Silicon Silver - gone
    2011 D4 TDV6 2.7 Indus Silver - gone
    IIDTool BT
    Mornington Peninsula
    Quote Originally Posted by kreddy View Post
    A friend did the Simpson Desert and Hay River track in a L494 Range Rover Sport fitted with 275/55/20 Pirelli ATRs. No rubbing and absolutely no problem. Speedo shows 102 kph when actually doing 100kph.
    I believe that BFG ATs are available in that size. I think Graeme has some fitted.
    2022 Defender D250 S being set up for touring.
    '83 RRC 2 door 300tdi on club plates
    '82 RRC 2 door almost finished on club plates (will always be nearly finished!)
    2013 Freelander (wife's)
    1994 Defender ute hopefully on club plates one day
