31st March 2006, 08:53 PM
Springz n other things done to death
Ok here is my question .....
has anyone run TUFF DOG springs in their Rangie ?
reason i ask ......I have brand new-ish Old Man Emu springs rated as Heavy Duty ...
eyebrow height drivers side rear 520mm
pass side rear 505mm
driver side front 510mm
pass side front 490mm
Now remembering Im in WA , and friehgt is the killer .....
Kings say this is normal and they can make it sit level for another $300 , Lovells said they can just make it level and sits at 1.5 inch over standard for $300 ......
Someone told me the best rated and lifted springs are TUFF DOG for Rangies .
I got a quote on Scorpion Racing Springs of $750 a set 8O 8O 8O 8O
at this point in time they are out of the question but i would like a goal to set for the future
31st March 2006, 08:59 PM
<span style="color:blue">when taking measurements...always measure from the bottom of the
guard (wheel arch) to the bottom of the rim.....this eliminates the variables from the
tyres...(ie...wear and pressure...)......</span>
31st March 2006, 09:04 PM
I was informed by 3 suspension shops to take the measurements from the center of the hub to the bottom of the wheel arch , this they said is the TRUE EYE BROW READING ......so i dunno just going by that
if it makes any difference all tyres are brand new about 3000km 235x85x16
31st March 2006, 09:08 PM
#4
<span style="color:blue">all you are measuring is the difference in suspension before and after
on each corner.....
the lip of the rim is much easier to measure from than trying to guess the
centre of the hub.....
will give the same result in the end....just more accurate....(as long as the rims
arent all bent....)</span>
31st March 2006, 09:09 PM
#5
ok standby gotta get my tape again :roll:
31st March 2006, 09:12 PM
#6
<span style="color:blue">these measurements are only good to check how much lift you gain
after the mods are done.....
or to compare one side with the other......
for all measurements...the vehicle MUST be on level ground.....</span>
31st March 2006, 09:15 PM
#7
ON LEVEL HARDSTAND
from the bottom of each rim to bottom of the wheel arch
drivers side front 715mm
driver side rear 745mm
pass side front 705mm
pass side rear 730mm
so its still all over the place :roll: :roll:
31st March 2006, 09:25 PM
#8
<span style="color:blue">is a hardstand the ground....?
either you need to put on a bit weight or get a lighter passenger.....</span>
31st March 2006, 09:34 PM
#9
hmmm i was told by ARB when i asked that it was normal for Rangies to lean even with brand new springs ....weird i thought 8O leaning to the drivers side i can understand with the weight of the transfer , steering , ect ect ect
But Lovells and Kings said this was not the normal
the other pain is the prev owner had them brand new sitting in their boxes so i fitted them , and yes fitted to the correct sides .
Hardstand is the concrete garage in my driveway .
31st March 2006, 09:37 PM
#10
And LR OEM springs are made with a higher drivers side bias.
www.members.shaw.ca/jbarge/springinfo.html
