Results 1 to 9 of 9
Thread: Disco 3 aircon
    Aug 2018
    Disco 3 aircon
    Hi all, I recently bought a D3 SE. The drivers side air con doesn't get cold at all. The passenger side does get cold, but not very cold. Any ideas on what may be causing the drivers side issue?
    Thanks for any comments
    St Helena,Melbourne
    1.13 MB
    Both controls set to the same temp ?
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Aug 2018
    Hi loanrangie, yea both the same temps or different temps doesn't change the outcome. However, if I put it all the way up to heat I do get hot air from all the vents. Just no cold air.
    BradC is online now Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    Have you had it regassed? We had similar symptoms, although ours were caused by a leaky Schrader (dumped the entire charge in less than 12 weeks). It might just be low on gas.
    Aug 2018
    Quote Originally Posted by BradC View Post
    Hi BradC, yea probably is a little low on gas, as it doesn't get really cold.
    St Helena,Melbourne
    1.13 MB
    Possibly the PS side control is faulty.
    1974 VW Kombi bus
    Aug 2018
    Sorry whats the PS?
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by vince64 View Post
    Sorry whats the PS?
    Passenger side.
    1974 VW Kombi bus
    Mar 2012
    melbourne
    If they are like the D1 and D2 the heater flow does not shut off and it is all operated by air flow . Our old D2 had the same issue on the drivers side, would always blow hot air on your feet because of a faulty shut off flap. Glad to be ride of that poor excuse for a 4wd
    Discovery 1 4.6, true trac front and rear, superior engineering arms,old tourer now bush toy
    Discovery 4 3.0 HSE MY13 ECB Bull bar, winch, spot lights, aux fuel tank, Kaymar rear bar, duel wheel carriers, 18 tuff ant wheels 265/65/18 BFG KO2's for play
