Results 1 to 10 of 13
Thread: D3 SE Air Compressor
    Dec 2011
    Adelaide
    I had a rear tyre let go at 110km/h today. A little sketchy to say the least. Then some absolute **** (me) put the jack in the wrong place and broke the cast aluminium bracket that holds the suspension air compressor in place. Yeah yeah I know.....I don't deserve a Disco...... Not one of my better days.
    Does anybody know the part number of that bracket? My new PC does not have a DVD drive so I cannot look at my RAVE files.
    I also damaged the plastic cover that goes under the compressor but I think some fibreglass of plastic glue may suffice for that.
    My car is an 09 with 134,000km. I wonder if I should change the compressor in case it is due to fail? I assume there are no rebuild kits?
    Cost of tyre blow out......RAA membership $289 (yeah yeah I had somebody change the tyre for me but not without trying - I just could not get the std jack under the s'pension and when I did it started to bend. Stuff that with trucks hurtling by at 110!). New tyre $269. Replacement bracket ?????? Grrrrrrrrrrr
    Quote Originally Posted by Mk1_Oz View Post
    RQU500064
    Enter your part no. into this web site's "search box" and get a list of prices from all major UK suppliers simultaneously, if you want to go down that route.
    Land Rover Workshop
    ... I assume there are no rebuild kits?
    You will find them on eBay as well as the below link.
    Air Suspension Repair
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Jun 2010
    Central Coast NSW
    The bracket is not usually under that much stress (unless you jack off it! D3 SE Air Compressor ) and when I cracked mine offroad I pulled it off and JB welded it up. Cost $15 instead of $150 or whatever they cost.
    Still seems to be holding up OK a year or so on.
    Dec 2011
    Adelaide
    Mine has crumbled!
    What's the deal with the air compressor itself? I realise that it will fail eventually but do people change them or put a kit through them before the fail point or just wait until it gives up the ghost? Just don't want it to fail when on a trip but it is an exy part to change unnecessarily.
    They tend to give you some warning before failure - slow to reach pressure set point which will raise errors relating to the suspension operation. In these cases it's worth refurbishing the things with the kits.
    If you are not getting these sorts of problems at the moment then possibly little to be gained by installing the kit but probably worth chasing up a kit as a spare so you can get on to when it does occur.
    If you do get symptoms of failure but ignore it then the problem can progress to cylinder and bore damage at which point the compressor becomes a throw away item.
    1984 RRC, in hell
    Jan 2010
    While you're ordering stuff you might want to get a compressor protection guard from Green Oval or APT (both forum supporters) if you do much off road travel.
    Ean Austral Guest
    From my limited knowledge it seems - well in my case - the main part that fails on the compressor is the plastic cap between where the air lines go thru it.
    Kits are cheap enough and there are a few you tube vids on how to overhaul the compressor.
    Cheers Ean
    Dec 2011
    Adelaide
    Thanks lads. I have a new bracket ordered from Rimmers. I will look at getting an overhaul kit then I can get back to worrying about when the plastic thermostat housing and EGR valves will fail lol
    St Helena,Melbourne
    1.13 MB
    Replacing the desiccant is a good preventative measure and is included in some of the kits.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Oct 2012
    Quote Originally Posted by Ferret View Post
    RQU500064
    Land Rover Workshop
    Wow! I never ceased to be amazed at what’s available
    My compressor is original Sep07 build. I did the desiccant and top cap service. It’s never faulted ever but can’t help but think along with suspension parts it’s time for a fresh one.
