Results 1 to 9 of 9
Thread: Atlas 4 speed transfer case
    Aug 2011
    Stanwell Park, NSW
    666.1 KB
    for those with too much money or need the flexibility of 3 low range transfer case
    Atlas 4 Speed Transfer Case Builder | Advance Adapters
    low range options
    Low Range:1.5:1, 2.72:1, & 4.08:1 or
    2.0:1, 2.72:1, & 5.44:1 or
    2.72:1, 3.0:1, & 8:16:1 or
    2.72:1, 3.8:1, & 10.34:1
    enjoy pondering the possibilities.
    MLD
    Current: (Diggy) MY10 D130 ute, locked F&R, air suspension and rolling on 35's.
    Current: (but in need of TLC) 200tdi 110 ute & a 300tdi 110 ute.
    Current: (Steed) MY11 Audi RS5 phantom black (the daily driver)
    Gone: (Dorothy) MY99 TD5 D110
    Jul 2011
    Yarrawonga, Vic
    Not Quite correct as in being the only 4 speed TC on the market, The Iveco Daily 4x4 has 3 seperate low range ratios . The Rock crawler ratio is planetary too .
    but for my money I'd have a Forbyn Series TC Replacement Transfer Case | Forbyn Bros.
    Aug 2011
    Stanwell Park, NSW
    666.1 KB
    wish i had known about this when i was trying to squeeze the front output shaft past the 6R80 auto. Subject to a suitable adaptor between the 6R80 and this unit and a lubricated shaft (like Ashcroft) it would open the way for the 3.2 Duratorq 6 sp auto conversion. Oh well that ship has sailed.
    MLD
    99.87 MB
    Quote Originally Posted by MLD View Post
    Do you think this could have worked with P38 axles that are LH drop??
    Slunnie
    Aug 2011
    Stanwell Park, NSW
    666.1 KB
    In theory it would work (won't know until you do a trial fit). The RHS of the 6R80 auto protrudes because of the valve body. Rangers have a LHD TFC and it's not a big unit but may have its front output flange lower than the LT230, which would add clearance to the auto. I've not put them side by side in correct orientation. I probably could because my gearbox is out with a stripped 3rd and the mechanic has ranger parts laying around.
    For a Defer would it require fabrication of the diff housing or do the P38 use the same radius arm set up (including mounting location on housing)? The nasty option is to use the ranger TFC (not low in gearing) or go to an altas or other LHD unit of worth. Using a LHD means changing the rear housing to a centre mount. Getting very expensive. My wallet hurts just thinking about it.
    MLD
    NSW far north coast
    Or an Ashcroft underdrive behind the LT230.
    Cray low, low low
    If you can still buy them?
    jbe's Avatar
    jbe is offline Master Silver Subscriber
    Nov 2015
    Yass
    Quote Originally Posted by rick130 View Post
    Cray low, low low
    Not when I looked for them last time
    May 2009
    When asked a while ago regarding fitting ashcroft ATB to centre, the diff lock lever seem to switch from 2wd to 4wd:
    Hi,
    *Ours does not use a center dif like the 230. its 2 or 4 wheel drive. Very strong and reliable. Not sure if that fits your plan.*
    Im happy to answer any other questions you may have.
    Thank you,
    Greg Forbyn
    Show quoted text
    Aug 2011
    Stanwell Park, NSW
    666.1 KB
    I rode in Dave's Jeep with an Atlas (his was 2 speed). The Atlas has 2 selectors - one selects H or L for the front output and one selects H or L for the rear output. In theory you can have the front in HR and the rear in LR or visa a versa or as the response from Greg alludes to, you lock the rear (in either H or L) and the front in neutral to be 2wd. If not set up right (cable alignment or tension) they can be a pain to engage between H and L.
    MLD
