Thread: Motorbike battery - max charge rate vs alternator output
    Now something to exercise those little grey cells.
    I need yet another battery for my 2007 Yamaha XJR1300. I don't ride it enough and it looks like the CTek XS0.8 charger that is usually connected might have boiled the battery dry. So I looked up the specs for the YTZ14S AGM battery used in the XJR and noted it has a normal charge rate of 1A and a max charge rate of 3A. The XJR alternator can output 28A which seems, at first glance, to be a little high!
    On a fresh battery, it probably wouldn't be an issue as the battery would be fully charged quickly - but what about an older battery?
    This may be all rhetorical as I don't have much choice but to buy a new battery but your inputs/thoughts would be interesting.
    Feb 2005
    Cannot help you on battery selection but I too suspected I cooked a battery leaving the charger on 24/7.....
    For my camper trailer I had it on a 7 day timer charging for one 24hr period per 7 days.....I than moved to a small solar panel where it trickle charged each day giving the batteries a rest at night.
    Queensland
    Hi Ron and weed’s suggestion of a solar panel is the simples and safest way to look after infrequently used batteries.
    Jaycar and Altronics use to have a regulatered, small milli-amp solar panels.
    These would be perfect for your situation.
    Free Again Thanks Dan
    I use a Projecta Battery maintainer on my bike over those bad months ,
    It puts out roughly 200 milli amps
    Does a brilliant job and never a issue
    St Helena,Melbourne
    4.28 MB
    I put a motobatt agm in my bike 6 years ago and apart from the occasional charge it's holding up well.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jul 2015
    Taupo NZ
    x2...good battery
    Better than mine. This will be the 4th (or 5th) battery in 10 years.
    Quote Originally Posted by Gordie View Post
    x2...good battery
    Um x3
    I just had a look on evilbay for a Motobatt YTZ14S equivalent and several suppliers are advertising "new & refurbished" batteries.
    What the heck is a refurbished battery? One that has been cleaned?
    I'm a bit leery of buying from any of them!
    Jul 2011
    Yarrawonga, Vic
    interesting discussion.
    I have a Century PS12180 12v 18Ah SLA motorbike battery in my Electric Landy as part of the ADR/ NCOP14 rule that states the Hazard lights need to work for 30 min in the event of a main traction battery fail.
    All the 12v electrics are hooked up to it . Lights / Horn / Wipers etc
    It also provides 12V to energise the Kilovac 2000amp contactors for the main traction pack.
    When the car is powered on a 50amp DC-DC converter keeps the battery charged at 13.8 Volt
    I wonder how long this little battery is going to live given that according to the Century website the safe charging rate of a Lead Acid is 10% of its Ah rating, which in my case would be 1.8Amp ????
    May account for the huge fail rate of Tesla 12 SLA batteries, which serve exactly the same purpose.
