2nd April 2006, 11:21 PM
found this site
A how to site for making an aircond unit into air pump with brackets ect ect ....
hope it helps :wink:
http://www.multiline.com.au/~psanders/air-...p%20install.htm
3rd April 2006, 09:24 PM
Cool....
i'm looking at fitting one to the Fender....
Now i have more idea's..... or i could just remove the Aircond and use it....
3rd April 2006, 09:41 PM
Air compressor
Geez I am a trendsetter, I had a magna compressor fitted up like that nearly 20 years ago (have Magna's been around that long??) Made my own brackets and its been on 3 Landies.
Never worried about lubrication or an air filter- after all its only used when you are stopped.
One thing this setup will do,just looking at it, is the heat will find it's way to the hose and it will pop off. It all gets pretty hot and you need about 6" of pipe between the compressor and the hose to dissapate the heat.
The other thing, is you will need some kind of water trap- especially when you pump up tyres in the misty Vic mountains, you can hold the hose against your hand and it will soon get wet. I used a standard air compressor water filter and it worked fine.
