Separate to the other thread.......
QLD are reviewing the rules around lifts and tyres........
Sooooo.I figured I would actually put a tape measure over and see how easily I comply.....but one need to know how high the suspension sat when new.
It appears Queensland Transport are working off a database and are checking suspension height from center of wheel to top of wheel arch. I cannot find anywhere in Qld where all the stock heights are listed, I assume they may have contacted each and every manufacturer and they have supplied the figures, it would be god if they published them.
OK, the best I can find is this website
Certification Unit Details it appears al manufacturers need to get an approval number and part of this is stating unladed and laden heights.
It seems a defender has the following, hopefully the attachment works
560mm Front Unladen (610mm with 50mm lift)
590mm Rear Unladen (640mm with 50mm lift)
and
525mm Front Full Bump
540mm Rear full bump
Centre of wheel, that easy
Top of wheel arch, umm....I assume top of flare? but the measurement don't add up, so i'm guessing its center of wheel arch (yep where the flare connects to) I roughly measured the flare and it about 95mm
My measurements to flare
505mm front with 130 (110HD) springs fitted
525mm rear with air suspension at 46psi
My rough measurements to guard (center of arch opening)
600mm Front with 130 (110HD) springs fitted
620mm Rear with air suspension at 46psi
q. I wonder what full bump means? I know I have way more than 20mm and 15mm bump stop clearance
Q. how do they measure on the side of the road......as they only have unladen and full bump measurements to go off........if I was 'un-laden' than I would be over height
either way I would be in for an interesting discussion as i'm sure they wont miss my rear coils missing
SCMP00218091709463 Road Vehicle Descriptor Suspension Heights.pdf
