Results 1 to 10 of 14
Thread: Electrolysis battery charger
    Feb 2018
    Adelaide
    G'day folks,
    Just wondering if anyone has any idea of a good power supply for electrolysis (for rust removal). I've heard that some of the newer chargers are too smart and will know they aren't hooked up to a battery.
    Any reason you want to use electrolysis, e.g., parts too big to put in mollasses/water solution?
    Western Victoria
    What about using an old plug pack?
    There are heaps around from old electronics equipment.
    What sort of voltage/current are you needing?
    I bought a cheap 240/12 volt converter from eBay, ($20) Works just fine.
    Electrolysis is so much quicker and cleaner than molasses and doesn’t stink.
    DAMINK Guest
    Old computer power supply always works well.
    Jul 2011
    Yarrawonga, Vic
    Just put rusty parts in Hydrochloric Acid + rinse + WD40, cleans them up as good as new.
    Apr 2016
    Country Vic.
    Quote Originally Posted by Kimsl70 View Post
    .... I've heard that some of the newer chargers are too smart and will know they aren't hooked up to a battery.
    Check the specs carefully on the chargers you're looking into.
    Some have a power supply mode and gives a constant 13.8v.
    as a quick example(not recommendation!) CTek MXS10 10 amp, has various modes/programs. Normal, AGM, Recond(recondition) and Supply.
    The Supply mode here outputs 13.6v continuous. It says use for power supply or float maintenance when 100% capacity of the battery is required, so you could use that mode to achieve electrolysis.
    Doesn't vary current in this mode, so assume it will output 10A continuously
    I've used PS mode to run a fridge at home, no worries.
    So if you have a smart charger, or are looking into getting one, just check the device to see if it has 'Supply' or similar as one of the selectable modes.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Feb 2018
    Adelaide
    Thanks all
    G'day all,
    Thanks for all the responses, I'm going with electrolysis for a couple of reasons, not as messy as the molasses (but I'm going to look into that more) and its something I want to learn. Thanks a lot re: looking at specs and some of the brands that work. Given the information that you blokes have provided I'll do some more homework. Thanks again, I really appreciate it.
    Jun 2008
    Drouin East, Vic
    I set up an electrolysis bath a few months ago for some tractor parts. Works in hours rather than months as with molasses. I used a very basic old battery charger that I no longer use after buying a modern one. Worked a treat. I reckon you'd pick up an old charger for pennies from a garage sale, flea market etc.
    DAMINK Guest
    I have done loads of electrolysis.
    Computer supply is great but laptop supply or any supply like that. Anything that drops the 240 down to around 12-24 volts will work.
    Very simple and reliable method. I have had baths setup for months at a time. Used it as a hand wash as well as parts cleaner.
    I guess you could even use a really small charger that drops to 12 volts but really low amps and that will still work, just take longer.
