Results 1 to 3 of 3
Thread: Uni-Joints for Pumas vs Tdi300 Defenders - What is the Differences?
    Jun 2013
    Warner Area - SEQ
    Question Uni-Joints for Pumas vs Tdi300 Defenders - What is the Differences?
    Guys,
    I'm trying to work out wha the differences might be between the 2 uni Joints. They are both 75mm across and 27mm cup but they both have different Part Numbers. Does anyone know what the differences might be?
    Rob
    (btw: Reason for asking is that I have spare UJ's for my Tdi300 and just wondering if they might fit my Puma)
    Jun 2013
    Warner Area - SEQ
    Question
    Quote Originally Posted by Robmacca View Post
    Guys,
    Rob
    Just reviving an old post.....
    Re: PUMA Front Driveshaft Uni-Joints, are they Different to the previous defender models and does anyone have the part code as well as the physical size?
    Puma front shaft uses a larger uni for greater operating angle, They are a 1330 series uni, as opposed to 1300 for defender and 1310 for rrc, county and s3. 1330 uni is 92mm across, 1310 are 82 from memory. A solid cross 1330 uni will take 1600nm, where a 1300 is about half that.
    I believe the REARS are the same as previous Defenders with the Fronts being different??
    Melrose SA
    The Defender TD5 used 1330 series UJs on the front shaft.
