Thread: 101 Master Cylinder Bore Size
    Aug 2010
    Sunbury, VIC
    Anyone know the bore size of the 101 MC? Is it the same front and rear?
    TIA.
    Apr 2011
    Wandong,Victoria,Australia
    Hi Gav,
    I have a funny feeling that I have a NOS master cylinder at home...
    How do I measure it for you?
    GG.
    88 Perentie FFR - Club Rego
    93 Discovery 1 200 Tdi - Club Rego
    03 130 Td5 Single Cab
    06 Discovery 3 Petrol
    22 Defender 90 - Full rego
    Aug 2010
    Sunbury, VIC
    Thanks - I'm after the bore size so piston needs removing - there will be a circlip in the end of it - once removed it will pull apart, but don't go to too much trouble if you're unsure.
    Western Victoria
    I've got a spare at home, too.
    What are you after, the seal size, or are you getting it resleeved?
    Aug 2010
    Sunbury, VIC
    Just after the bore size and wondering if the bore for the front and rear are the same is all. Just thinking out loud at the moment. 101 Master Cylinder Bore Size
    Quote Originally Posted by Homestar View Post
    But we cannot hear you
    Aug 2010
    Sunbury, VIC
    Everyone here at my place can - they often tell me to shut up...101 Master Cylinder Bore Size
    Jan 2008
    Nowra NSW
    From memory both sides of the master cylinder is the same bore of the same size.
    I believe a series three master cylinder will fit and work correctly, except one brake pipe outlet is in the wrong spot.
    If you rework the pipes a series three master cylinder works.
    Jan 2008
    Nowra NSW
    Looking at a old post.
    Progress report.
    the photo shows the out side of the master cylinder being stepped...………….now none the wiser.
    Aug 2010
    Sunbury, VIC
    Thanks, don't need to replace mine either, just doing some research. 101 Master Cylinder Bore Size101 Master Cylinder Bore Size
