Try running a jump lead from the battery earth to the starter motor body to elimate a bad earth . Also it could be too far advanced.
When i turn starter over with ignition off all is well . When I turn ignition on and press starter, is struggles to turn engine over . (80 inch, 2 litre)
You always pull the coil lead out of dizzy cap then crank if it spins over ok its timing
1960 series 2 143001010
1976 series 3 91331709c
06 discovery v6
2014 discovery tdv6
2010 cub supamatic drover
Yes timing thanks heaps !!!
