Without auxiliary battery a lead with Anderson plug is the best solution.
All,
What are you doing for aux power for external accessories? ie when I want to power my TJM compressor which is 30A or 360w.
The car's aux power sockets are limited to 120w.
Use the jump point under the bonnet? Doesn't sound like a good idea...........
I am thinking I need to run a fused lead from the battery to the jack storage and put an anderson plug on the end.
Cheers.
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
What would be the reason not to use the jump point under the bonnet? I was planning to fix an ARB compressor in the space behind the driver's side headlight, which is next to the jump point. I would have thought the capacity of the lead (I think there is a positive lead only) is sufficient for a compressor if it can be used to jump start the car?
Ron
2016 D4 TDV6 Corris Grey
2018 D5 TD6 SE Silicon Silver - gone
2011 D4 TDV6 2.7 Indus Silver - gone
IIDTool BT
I assumed you meant in the rear , jump point and a suitable earth should do the trick.
1974 VW Kombi bus
Good to know, yes there is a positive terminal under the bonnet and next to it an earth point.
Ron
IIDTool BT
No reason other than LR love to complicate things and it would not surprise me to find some small print warning about using the jump start terminals for something other than jump starting. That said the manual is written in terms of the donor and the disabled vehicles and does not nominate which is which so you'd think there would not be any dramas connecting a 30A, 12 volt compressor.
I use the jump start terminals under the bonnet of my L405 for my 65A ARB twin compressor without any issues. They are just a direct connection to the battery terminals in the rear. Obviously, shorting the positive to earth is not a good idea and any permanent connection would need to be fused, just as they would be if connected to any other battery terminal.
Bob
